I've a silly question(to most of you) to ask, so please don't mock me.
Very unlikely to happen here.
18-105 lens covers all rangers between 18-105 right? I mean if i don't zoom at all, its 18, and if i zoom all the way, its 105, right??
Yes.
So why would i buy 35mm or 55mm seperate lenses if 18-105 covers them all?
Thats actually a great question, and reason to many discussions.
One of the main reasons is that a 35mm f/1.8 or 50mm f/1.8 (or likewise prime lenses with large apertures) give you a lot more light, allowing to take pictures indoors or in less great light without needing a flash too early.
The other is the creative possibilities you get with having a much more open aperture, which not only gives you more light, but also a smaller area of sharpness. This is for example great for portraiture, when the background is unimportant and should be preferably completely unsharp. People actually love to use really expensive glass, like the 85mm f/1.4 or the 135mm f/2 on a full frame sensor, just to get that effect. Its of course even more drastic on medium format cameras.
Another reason of course is that a prime lens (i.e. a lens of fixed focal length) is smaller and more lightweight, simply adding to the sheer fun of photography.
Another reason is that for certain purposes, like very long lenses, tilt/shift lenses, or macro lenses, prime lenses are still pretty much standard. For example, focusing a macro lens is best done by moving the camera, so neither autofocus nor zoom is too important anyway. Also, macro lenses are by tradition extra sharp, a goal which again is helped by make them prime lenses.
And in many situations you can just "zoom with your feet". Whenever this is the case, using a prime lens is definitely no issue.
A very important aspect is also that different focal lengths do NOT, I repeat: NOT, just get you closer or more far away from your subject. A much more important question is the question of perspective.
A socalled "normal" lens, i.e. about 35mm on your APS-C size sensor, or about 50mm on a full frame sensor, will give you natural view. That means a lens like that will show objects in increasing distance in a natural decrease of size.
A long lens however will "flatten" your subjects, i.e. objects that are far away will not actually decrease in size as much as it would be natural. On the other hand, you can now keep your distance to your subject.
Wide lenses of course do the opposite - thats why you really have to get close with them.
A final reason is that you often dont really need more than a prime lens. For over a century, zoom lenses have been practically unknown. All the famous images of these times have been made with prime lenses. For example, Henri Cartier-Bresson reportedly only had a 50mm prime lens for his Leica, for decades. Or the recently discovered Vivian Maier used nothing but a "compact" (i.e. you cant change the lens) medium format camera (a Rolleiflex dual lens reflex camera) for her work. Theres quite a lot of fixed lens compact cameras out there (Ricoh GR, Nikon Coolpix A, Fujifilm X100 and its successor X100s, Sony RX1, Leica X1 and X2, Sigma SD1 to SD3 Merill), which is probably also caused by the fact many people are used to mobile phone cameras now (which, due to size constraints, usually have fixed lenses).
Can i get the same "Bokeh" with the 18-105 that people get with those 35mm or 55mm lenses?
Bokeh describes the quality of the unsharp areas mentioned before. This is a property of the lens. My 55-200mm for example can produce gorgeous, creamy Bokeh at 55mm. Since its only f/4, this however needs more distance between subject and background than for example someone with the 135mm f/2 DC.
It should be noted that Bokeh is a question of taste.
