Charbear
- Joined
- Dec 1, 2020
- Messages
- 1
- Reaction score
- 0
- Can others edit my Photos
- Photos OK to edit
First post here. I've had my Rebel 7Ti for a couple of years now. I mostly use it for waterfall photography (with a tripod of course). As opposed to using a shutter release cable, I've primarily been taking the shots using the timer (a lot of my shots are a 0.5 - 2 sec exposures). If I recall correctly, I would partially depress the shutter to lock in focus, then push it all the way down to start the timer. I usually take 3 exposures of each shot (often +-2/3 stops).
This last round of pictures, many came out quite blurry. Perhaps I somehow messed up the focus? The only thing I believe I may have done differently is to put the timer on 2secs as opposed to 10secs. I might have done that during a previous session or two..not sure..but if I did, those shots turned out fine.
Do the experts on here see an issues with using the timer as opposed to a shutter release when taking longer exposure shots using a tripod? If so, could someone please describe why and also provide a bit of education on how to use/improve either the timer process or the shutter release cable process?
Thank you!
Thank you!
