What Tripod should I get for my Canon 5dsr
Maheen
I need a nice tripod but there is very limited choice in the country I live.
Benro-KH-25 is one of the choices, i was told by the shopkeeper to get this one. is this the correct choice.
Not sure as to that as can not link to view it
Make a list of what you want to do with camera tripod combo and if you are going to be using heavy or large lenses
You will want to look at something that is rated for your camera lens combo
Is it for indoor or outdoor travel use, there are a number of threads here with these Q answered
So, i need it for both indoor and outdoor photography. right now I have a Canon 5DSR and 2 lenses-one is 50mm and other is 85mm.
Believe this is the one the OP is referring to. If so, it's more than sufficient to support the camera and lenses. However, it does weight 7.5 lb/3.5 kg. A little on the heavy side, but should be sturdy.
Benro KH25N Video Tripod Kit
This looks like a very good tripod. :1247:
Thats the equivalent of putting a 460 into a Smartcar.
Not that you cant, but its a bit overkill.
For the 5D it'll be fine and in fact really good if using heavy lenses.
