Dave Colangelo
- Joined
- Apr 27, 2016
- Messages
- 452
- Reaction score
- 159
- Can others edit my Photos
- Photos NOT OK to edit
Generally speaking there is little practical difference between late all mechanical cameras and early electric shutter cameras. The big difference is that the introduction of electric shutters allowed for what is affectively Aperture Priority mode originally called "Auto". Most of the nikons people have listed here have electric shutters (including the FE and F3 I listed). These cameras offer full manually operation and include a decent built in meter as well as an "Auto" Mode.
In terms of reliability that depends how you look at it, I own a few of each and in practice a good example of either is a good camera. On electric cameras you tend to see corrosion, element degradation in the meter elements, burnt out LCD's and the such when it comes to what breaks. On the all mechanical devices you see timing drift, gummed oil, shredded gears, seized components and tired springs ultimately take them down. However, all mechanical cameras can often be serviced and brought back to life.
On the battery note early electric shutter cameras are barely dependent on them. I put a battery in my F3 2 years ago and its still churning just fine I also use it a fair bit. These cameras hardly chew batteries. Even all mechanical cameras may take a battery to operate the internal meter (if there is one). On that front many of these cameras take a type of 3V Mercury battery that is no longer in production and you may have issues getting the internal meter to work without it. There is lots out there on this topic. You may end up with a selenium cell meter which can drift over time so I don't always trust them. You can be completely battery free with a properly adjust mechanical camera and a known, good, selenium meter.
The important thing when buying any used camera is not how it looks but how it fires. A beat up body that was recently serviced is always a better choice than a pristine body thats been sitting in an Attic in a box for years. You need to check the lenses for dust, and more importantly fungus. Check the shutter for operation at slow speeds and high speeds that at least sound somewhat right.
Im seeing a lot of FE's available here in the states for <$150 and i would think you can find them where you are as well.
). There are quite a few spotmatic bodies on
