Pick a focus length on the zoom. Back away from subject, auto focus, turn on m focus, gradually move up and adjust m focus ring (not the zoom) until sharp. Keep moving forward until you reach the closest point where you can still achieve sharp focus. That’s as close as you’re going to get. You can play with the zoom to see if that makes a difference in getting you closer. Keep in mind that most zooms are not at their sharpest at either extreme.
hi thanks so much. however, when when i manual focus and then i magnify it using the button near viewfinder it is blurry when i try to move my camera closer it is still blurry no matter how much i change the focus ring where it says the number in meters all the way to infininity. i try to adjust the diaopter to seee if it fixes anything (it is clear for my eyes on the viewfinder, not blurry, so i know this is not thee issue)
