amolitor
- Joined
- May 18, 2012
- Messages
- 6,320
- Reaction score
- 2,131
- Location
- Virginia
- Can others edit my Photos
- Photos OK to edit
Just to extend my sailing parable a little bit.
If you're not a very good racing sailor, then sanding the bottom of your boat to a mirror finish isn't going to help you. You're not going to win races until you get to be better at a lot of different things. When you do become a good racing sailor, one of the things you have internalized is that everything -- absolutely everything -- should be done right. Competing at a high level is about doing everything right, and taking every edge you can, no matter how small. Why? Because there are other blokes out there who are just as good.
Sanding the bottom of your boat to a mirror is a psychological trick, which is one of 10,000 things you do when you're winning a lot of races, to make those wins happen.
Shooting film is going to make you work differently. There's simply no getting around that. If you're sufficiently manly you can maybe reduce the effect to a very very small one, by controlling your tools and not letting them control you, but the fact that you're carrying this camera with these limitations is going to change the way you work.
If this change, however small, is in the right direction, why wouldn't you take it? If you want to make the best pictures you can, you need to take every edge offered to you, you need to use every trick, you have to do every single thing the best you can, otherwise you're taking pictures that are, at best, almost but not quite the best pictures you can. You're not competing against other blokes here, you're competing against an idealized notional version of yourself, one who makes literally no mistakes.
