- Joined
- Mar 8, 2011
- Messages
- 25,393
- Reaction score
- 9,148
- Location
- Iowa
- Can others edit my Photos
- Photos NOT OK to edit
I guess we should all do things Wayne's way or else we're failures.
might have something to do with purpose of photo. Jpegs are damn good and will show negligible if any difference in many cases. some cases though, yeah, go to the raw...Something usually left out of the discussion is this:
Almost none of this matters if you're reducing the size of the final output. You can trade lateral resolution in for bit depth, any time, and with great success. Edit that JPEG all you want. Artifacts all over the place, ugh. Now reduce it to 640x480 for use on the web. Boom, virtually all the artifacts are gone. Ugly posterization is blended away. Block chunky crap is smoothed right out. Blown highlights are shrunk down to tiny white dots that actually look pretty good. Etc.
Since almost every photograph that is ever seen by anyone other than the photographer is radically reduced in size, it doesn't matter all that much how you do it.
Just another way to say that some people simply don't care about best quality.![]()
course, there are those that believe every single photo has to be the highest quality artwork and are ocd. But that is another story and not often found in those that shoot a lot of general purpose photos I would think.
I steer the more important ones toward raw, the ones going to print more likely will go to raw. Or if I am planning on friggn with it then it will go to raw. Never really felt the need to use raw for every image. Not a pro though. If I was more photos would be going to raw they would count more (paycheck)course, there are those that believe every single photo has to be the highest quality artwork and are ocd. But that is another story and not often found in those that shoot a lot of general purpose photos I would think.
Mine are hardly artwork, and while I've done this camera thing for many decades, I still seem unable to guarantee every frame will be perfect. Things just happen, you know? The camera white balance tools are so crude. Bright sun is decent, but incandescent is impossible, and flash varies with power level. I think it can be closer than Auto.And reflective light meters are crude in their way. At least sports can take time to get their first one right, and then shoot away.
But Raw is so easy and so fast and so good, they become totally trivial to fix right. Why do you think there are so very many raw advocates? New game in town, and I promise Raw can change your life.One should at least look into it.
Aside from recovering blown highlights or under exposed shadows to a point, if you can’t edit a JPG as well as you can a RAW file, then you need to go back to the drawing board.
Simply not true. You must not have any Raw experience? Minor adjustments can work in JPG, but any major shifts suffer seriously. Raw has much more range for edit. Shoot a JPG in Incandescent but as Flash, and then try to fix it? (enough to actually be good).
But there is much more...
With Photo Shop once you open the file past the first Adobe raw editor you can make the exact same edits and once in PS, you can do the same edits past recovering exposure that you can in ACR.
Raw has camera oriented tools, like White Balance and Exposure tools. Photo editors don't.
Photo editors (including Photoshop) have graphic oriented tools, general purpose.
Like PS Color Balance... RGB Color Balance has three adjustments for Shadows, Midtones, Highlghts, possibly meant to be versatile, but what we need is an easy tool that does WB on the whole photo range. Plus it is RGB. How do we do those three RGB, and the three tonal degrees, in the right porportions for WB?
Yes, we can shift to Lab color to have the two necessary sliders (aka WB), but there is still the three: Shadows, Midtones, Highlghts.
Raw offers the actual WB tools, two sliders instead of six,, excellent tools for the specific purpose. Calibrated in degrees K. Plus presets for Daylight, Incandescent, Auto, etc.
Easy, fast, good. Built for the job.
And while Levels White Point is Exposure, Raw calls it Exposure.
Plus Raw is lossless edit, and RGB is not. We are always working from the baseline of the original raw image pixels (we can uncrop for example). Then Raw does any data tonal shifting only the one final time to output RGB.
In RGB (JPG), one edit starts at the previous edits results, needlessly shifting tones back and forth. That's not good. That's the pits.
(OK, Adobe Raw software does also offer opportunity to do lossless edits on JPG, and the Raw tools are better, but JPG is still 8 bits).
These are all pretty big deals for anyone that knows and cares. Not everyone does know or care. But if you care, and have a few extra minutes, you should try Raw. It can change your life.
Sports photogs with a one hour schedule certainly do have a rush issue. Fortunately, they are blessed with most shots being the same field scene, one setup. Wedding has it tougher, indoors in a dark church, outdoors in sunny reception, etc.
Amateur has it worst, in all possible conceivable scenes.Needs more individual attention.
Of course nothing ever changes when shooting sports, I set the exposure before I leave the house and away I go, that must be why so many people say they can shoot sports, it's only one setting to get it right.course, there are those that believe every single photo has to be the highest quality artwork and are ocd. But that is another story and not often found in those that shoot a lot of general purpose photos I would think.
Actually, I'm thinking of shooting jpeg just to sharpen my metering, I am getting lazy knowing I can fix it in post.)course, there are those that believe every single photo has to be the highest quality artwork and are ocd. But that is another story and not often found in those that shoot a lot of general purpose photos I would think.
For me it does matter how that final image is made. Don't really so much care what others do but on a personal level it really matters and I will tell you why.As I drift back through past memories of identical threads, I have to admit to losing a slight chuckle at some of the age old arguments.
Only the final product matters....
as long as you shoot in manual, raw, and get it mostly right in camera (it must be a full frame camera of course)
the real truth is...if you print that image, (or strip exif data) noone has any clue whatsoever what you shot, how you shot it, or how it was processed...The workflow is completely irrelevant, except to the person doing the work.
Personally, and i mean strictly speaking for my own personal workflow preferences, I edit every file. yup. every file i deem not bound for circular file 13. (i only work 10 days a month, and I don't do a ton of photo work...i got time for it) Most go through LR, a small amount through PS. They all get at least some minor adjustments, even if im just moving some sliders around to see how it would look a few different ways. That being the case, there is little to no reason for me not to shoot raw since there would be no real change in my workflow shooting jpegs, and I retain the advantage of the extra data in raw files in case i need it.
but heres my actual answer as to why someone should shoot raw.
ya ready?
Because you feel like it.
yup. that's pretty much it. If it feels good, do it.
It doesn't matter one wheat cent to me how you get the picture you wanted. In photo editing, the ends really do justify the means.
you want to shoot in jpeg? go for it. aperture priority? full auto rapid fire? who cares.
im sometimes amazed that there are people that care more about critiquing camera settings than the actual picture.
crap this rant is going on forever....hold on, let me wrap this $#&^ up.
my point is...
don't be a racist.
raw and jpeg can coexist in harmony.
