Wide angle lens for the Sony A6000?
marchvet
Hampton Virginia
Looking to get a wide angle lens for the Sony A6000. I am VERY new to photography and wanted to do timelapse and am wondering if a wide angle lens will make it look better?
I currently own the stock lens and the E-55 lens.
Um … why not try setting up a composition you like? If you feel the shot you can capture with your camera/lens combination doesn't stretch out wide enough, then yes, you need a wider lens for that. It all depends on the shot; doesn't really matter if it's a time-lapse, a video, or a still image.
I second that. If you shoot timelapse of growing plants, you don't need a wideangle. For spectecular lenscapes, it might be awesome.
I use a wide angle lens for 2 basic purposes. 1) to fit more into the frame when I am running out of room to back up and 2) to make thing in the foreground look closer (bigger) and things in the background look much smaller or further away. I think this is call "exaggerated perspective". As for timelapse? I don't see where a wide angle will make any difference over a normal or even tele lens.
