sashbar
- Joined
- Dec 13, 2012
- Messages
- 3,044
- Reaction score
- 1,183
- Location
- Behind the Irony Curtain
- Can others edit my Photos
- Photos NOT OK to edit
What exactly is wrong with Sony lenses?
Nothing especially with the new ones coming out, but I will still use my M adapter and lenses, Nikon shooter don't like manual focusWhat exactly is wrong with Sony lenses?
Nothing, these are good lenses, simply too few, Sony is really cheap in coming with lots of them especially fast zoom lenses.What exactly is wrong with Sony lenses?
Not sure saying Nikon users dont like MF, do you know all Nikon users in the world ?Nikon shooter don't like manual focusWhat exactly is wrong with Sony lenses?
Have you checked out the Df? Maybe 16mp isn't enough but the low light capabilities are pretty damn good.
You can add a wifi SD card to any camera.
Yes, the df controls are the most counterintuitive things ever. Not a fan. But I do like its looks though.
Well it makes perfect sense considering if you want 17mm tilt-shift or 11mm ultra wide (which are both great for landscapes and architecture, as is the OP's requirements), you can only get it with Canon systemAgreed. I love the A7 but I wouldn't get one till Sony bothers to get more serious with their lens offering to this camera.I have looked at the a7 series, but the lack of lens options is a turn off. I know it can take on all sorts if lenses with adapters and things, but it's just not the same..
To me it makes no sense to buy a Sony camera then attach to it lenses from another maker through an adapter that in most cases will not AF and even if it AF in Canon lenses case it AF really slow.
If I am not mistaking getting and F4 lens on FF is like getting F2.8 on APS-C so why would I want to get FF ?In terms of proprietary lenses, it's actually got quite a good selection, there's the Zeiss 55mm F1.8, 16-35 F4, 24-70 F4, 70-200 F4. Sure they're F4, but considering it's full frame it's equivalent to a F2.8 on a crop sensor like the X-T1 anyway
However Canon bodies are crap for these types of photography, Sony sensors are much better
and you can't adapt Canon lenses to Nikon SLR bodies so, A7 series is literally the best you can have
Sure AF won't be as good as the proprietary, but considering the genre and the awesome focus peaking, I don't see how that's much of an issue
F/4 is f/4 regardless of what sensor you're using. Full frame sensors don't magically make things twice as bright.Well it makes perfect sense considering if you want 17mm tilt-shift or 11mm ultra wide (which are both great for landscapes and architecture, as is the OP's requirements), you can only get it with Canon systemAgreed. I love the A7 but I wouldn't get one till Sony bothers to get more serious with their lens offering to this camera.I have looked at the a7 series, but the lack of lens options is a turn off. I know it can take on all sorts if lenses with adapters and things, but it's just not the same..
Full frame is 2x bigger than APS-C therefore twice the light captured per frameF/4 is f/4 regardless of what sensor you're using. Full frame sensors don't magically make things twice as bright.Well it makes perfect sense considering if you want 17mm tilt-shift or 11mm ultra wide (which are both great for landscapes and architecture, as is the OP's requirements), you can only get it with Canon systemAgreed. I love the A7 but I wouldn't get one till Sony bothers to get more serious with their lens offering to this camera.I have looked at the a7 series, but the lack of lens options is a turn off. I know it can take on all sorts if lenses with adapters and things, but it's just not the same..
well because:If I am not mistaking getting and F4 lens on FF is like getting F2.8 on APS-C so why would I want to get FF ?In terms of proprietary lenses, it's actually got quite a good selection, there's the Zeiss 55mm F1.8, 16-35 F4, 24-70 F4, 70-200 F4. Sure they're F4, but considering it's full frame it's equivalent to a F2.8 on a crop sensor like the X-T1 anyway
I want F2.8 on FF so I can choose what aperture to use and get that extra light in if needed.
That depends pretty wildly on what camera you are using. Sure FF has an advantage ISO wise, due to having larger pixels, but sensor technology has drastically overtaken sensor size as the more important determinant of high ISO capability.Full frame is 2x bigger than APS-C therefore twice the light captured per frameF/4 is f/4 regardless of what sensor you're using. Full frame sensors don't magically make things twice as bright.Well it makes perfect sense considering if you want 17mm tilt-shift or 11mm ultra wide (which are both great for landscapes and architecture, as is the OP's requirements), you can only get it with Canon systemAgreed. I love the A7 but I wouldn't get one till Sony bothers to get more serious with their lens offering to this camera.I have looked at the a7 series, but the lack of lens options is a turn off. I know it can take on all sorts if lenses with adapters and things, but it's just not the same..
more light captured = less interpolation for equivalent ISO = generally 1 stop better ISO performance, this cancels out with the aperture
You can test this by using a full frame camera, set it on a tripod, shoot a picture at say 70 mm F2.8, ISO 1600, then shoot another picture at 105mm F4.0, ISO 3200, then crop the first picture to APS-C frame (to mimic APS-C) camera
What you get here is two shots, same framing, same FOV, same pixel density, different aperture, different ISO, but the noise levels (and depth of field) will be almost exactly the same
fjrabon said:F/4 is f/4 regardless of what sensor you're using. Full frame sensors don't magically make things twice as bright.
yeah, it went so far the other day as some dude tried to claim that medium format lenses "let in more light and give a totally different look."fjrabon said:F/4 is f/4 regardless of what sensor you're using. Full frame sensors don't magically make things twice as bright.
Yeah...there is this unusual new misinformation/oddball thinking/screwed up conceptualization sweeping the internet, where "tech" writers have begun saying that a full-frame sensor "lets in more light" than a smaller sensor...which is really a dumb way to look at this. Apertures are relative to the lens focal length used, and in terms of exposure f/5.6 at 1/250 second is the "same exposure setting" on a 4x5 sheet of film, or on any sized sensor...if the light level at the scene requires an exposure of f/2.8 at 1/60 second, every single camera must be set to the same settings, no matter the capture size, in order to arrive at the right exposure of f/2.8 and 1/60 second.
And thats why I sold my DX and got FXwell because:If I am not mistaking getting and F4 lens on FF is like getting F2.8 on APS-C so why would I want to get FF ?In terms of proprietary lenses, it's actually got quite a good selection, there's the Zeiss 55mm F1.8, 16-35 F4, 24-70 F4, 70-200 F4. Sure they're F4, but considering it's full frame it's equivalent to a F2.8 on a crop sensor like the X-T1 anyway
1. similar price
2. better image quality
3. adapt other full frame lenses
