Zoo Pics CnC Welcome
I only like the second one and it's borderline.
I think BT hit the nail on the head with other advice, so I'll give you advice on the second one, and if you know this I'm super sorry it just bugs me with a lot of shots.
The corners are the problem: The right side is good, but other things are leaking in from the sides (other than the green leaves). Cropping it would work in this case because you set the subject far enough to one side, but it won't always work, so be careful to adjust your positioning carefully (check your corners!).
