You could try some gells in front of the lens. It will give you much better control of the exposure then trying to open the door. Cokin makes some accessories that make using gells easy.
It looks like a chemistry/development problem to me. There appear to be no cyan or yellow colour couplers formed in the magenta bit.
Fogging the film would still have produced these.
Not impossible to duplicate but very difficult. It would take quite a while to do it and probably be expensive.
Filters over the lens wouldn't produce the same effect either.
The best way would be to get it into PS and then fiddle with the three colour layers using seperate masks. The colour layers mimic the tri-pack structure of colour film so you should, with a bit of thought and experiment, be able to reproduce the effect exactly.
*edit* Giving it a second look there appears to be some yellow forming in there too. It would appear that it is mainly the cyan layer that has gone West.
I find that difficult to believe, but strange things have been known to happen in Photography..
If you fogged the film - which is what happens when you open the back and let light in - you would find exposure variations as well as colour variations.
The bits where the colour has changed would presumably be the bit that got fogged.
If it's colour neg then you would have the exposure plus the fogging which would make the neg denser on that part and therefore it would print lighter.
It seems to print pretty much the same as the normal bit.
You would also expect to get at least some cyan in there from the original exposure but there appears to be absolutely none.
To tell you for certain I would need to see the actual neg.
If you want to duplicate it I would still recommend the Photoshop route. You could waste an awful lot of film without getting anywhere near that effect again.
