Lens Question
Discussion in 'Photography Equipment & Products' started by kayliana, May 20, 2010.
  1. kayliana
    kayliana TPF Noob!
    Aug 3, 2009
    109
    Overton, Nv
    I was wondering if anybody has any suggestions on what a good canon lens for portrait would be? Thanks!
  2. KmH
    Apr 9, 2009
    38,726
    5,153
    Iowa
    Wide angle lenses distort a persons features to much.
    Anything from about the 50 mm focal length and up work just fine.
    Some of the most stunning portraits are made with at a 200 mm lfocal length. As theocal length increasea the photographer has to be further from the subject
    Wedding photographers usually use two main lenses, a 24-70 mm and a 70-200 mm.
  3. tsaraleksi
    tsaraleksi TPF Noob!
    Jun 12, 2007
    1,045
    Greencastle Indiana
    It depends on what kind of portraits you're doing. Traditional headshots need something in the 85-200 range, but full body shots might call for something wider, as would be the case for environmental portraits and other non-traditional applications.
  4. Big Mike
    Dec 16, 2003
    33,831
    1,812
    Edmonton
  5. Derrel
    Derrel Mr. Rain Cloud
    Top Poster Of Month
    Jul 23, 2009
    36,740
    13,459
    USA
    Canon's EF 85mm f/1.8 is a good prime that works well for portraiture. It is light, easy to handle, sharp, focuses well, and indoors in most rooms is good for half-body to headshots. The price is affordable.
  6. cfusionpm
    cfusionpm TPF Noob!
    Jun 21, 2009
    852
    6
    San Diego, CA
    On your XTi, a 50mm 1.4 would be an excellent choice. If you're on a budget, the 50mm 1.8 is a lot cheaper, but it's not nearly as well made. (~350$ vs ~100$).
  7. gryphonslair99
    gryphonslair99 Been spending a lot of time on here!
    Sep 9, 2006
    12,026
    2,210
    Wichita, Kansas, USA
    Anything above 50mm that fits your working room will work. You want a lens with sharp optics and a high number of aperture blades with rounded ends. One big downfall with the 50mm f1.8 is the fact that it only has only 5 non rounded aperture blades that really effect bokeh.
  8. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    345
    North New Jersey, United States of America
    Unless you are looking for pure fast aperture speeds, I don't see much of an advantage of the 85 f/1.2L. There's a reason why fast glass users (Like me) usually also have a "normal" aperture lens also in the stable. They are more "specialized" lenses. At least from what I've shot, f/1.2 isn't going to be a common aperture you will use for portraits.
    I've owned the 85mm f/1.8 for years.... I wouldn't hesitate to recommend it to anyone as a portrait lens. The 50mm f/1.4 as well... better than the f/1.8 even though it too is a good, more general use prime.
    I'm surprised no one has mentioned the 100mm macro.... Good macro but also valued by many as a portrait lens. I personally passed it up for the 135mm f/2L .. again.. fast glass.
