Camera Terms and Acronyms for Dummies
Status
Not open for further replies.
This was such a great and informative read! Thanks
I am not a newbie but I have no idea what a TF shoot is. Anyone?
We have deleted lots of SPAM posts from this thread, and have permanently banned most of the members that had posted it.
:bounce: So links for fiddle lessons, sue your lender, image recovery software, building contractor, business lending, vote for my photo, UK kitchen remodeling, live stream sports, mobile device/phone sales, links hidden in emoticons, yada, yada, yada, are not allowed and will be bounced. :bounce:
Please use the Report Post triangle at the bottom of each member profile there on the left, and report suspected SPAM post/links.
Here is a good one, and per wikip :
pixel - hot - is what someone told me. The "bright pin hole overexposed dots" in my long time delayed photos :
[h=1]Defective pixel[/h]Defective pixels are pixels on a liquid crystal display (LCD) that are not performing as expected. The ISO standard ISO 13406-2 distinguishes between three different types of defective pixels,[SUP][1][/SUP][SUP][2][/SUP] while hardware companies tend to have further distinguishing types.[SUP][3][/SUP]
A photograph taken with a damaged image sensor​
Similar defects can also occur in a charge-coupled device (CCD) or CMOS image sensor in digital cameras. In these devices, defective pixels fail to sense light levels correctly, whereas defective pixels in LCDs fail to reproduce light levels correctly.
Este foro es muy util para saber de que te hablan cuando sales de camarografo a los rodajes de la productora !
Hello, sorry to reply in this post...I am a newbie and was wondering how to start a new post, thank you :)
Thank you for posting this. I'm very new to this and hope to gain all the knowledge and information that I can!
~Churdy
Great summary! Thank you!
For you people that don't know the terms we use :P. And yes some of these are going to sound stupid :D (the things in brackets are dummy definitions :P, if no brackets then its just my definition) (Sticky much?)
Ambient Light
The available light completely surrounding a subject. Light already existing in an indoor or outdoor setting that is not caused by any illumination supplied by the photographer. [Light the photographer didn't create ie. Sunlight, lightbulbs already in the room etc.]
Angle Of View
The area of a scene that a lens covers or sees. Angle of view is determined by the focal length of the lens. A wide-angle lens (short-focal-length) includes more of the scene-a wider angle of view-than a normal (normal-focal-length) or telephoto (long-focal-length) lens. [What the lens sees, kind of like what you see when you look at something]
Aperture
Lens opening. The opening in a camera lens through which light passes to expose the film or sensor. The size of aperture is either fixed or adjustable. Aperture size is usually calibrated in f-numbers-the larger the number, the smaller the lens opening.[the f/ number thing, controls exposure and depth of field, also know as the blade things inside the lens]
Bokeh
The blurry part of the photo achieved with a narrow depth of field.
Bracketing
Shooting 3 or more shots with an equal stop difference between each one, usually used for HDR's
Chromatic aberration
Commonly seen as colour fringes at the edge of subjects caused by the inability of the lens to focus all wawelengths of light at a single focal point. Will also affect sharpness. Low dispersion glass is used to correct this. Canon L series, Nikkor ED, Sigma DG, Sony G, also labeled as APO.
Composition
The pleasing arrangement of the elements within a scene-the main subject, the foreground and background, and supporting subjects.[How you set up subject and props of the photo]
Crop Factor Sensor
Size of the sensor is smaller than a 35mm film frame. Most common crops are 1.3X, 1.5X (Nikon), 1.6X(Canon), and 2.0X(3/4ths systems)
Cropping
Printing only part of the image that is in the negative or slide, usually for a more pleasing composition. May also refer to the framing of the scene in the viewfinder.[Cutting out parts of the image by decreasing what you see on the sides]
Depth of Field
The amount of distance between the nearest and farthest objects that appear in acceptably sharp focus in a photograph. Depth of field depends on the lens opening, the focal length of the lens, and the distance from the lens to the subject.[Blurry Background]
Digital lenses
Canon S, Sony DT, Tamrom Di II, Sigma DC, Nikkor DX, Pentax DA - have a smaller image circle specifically designed for APS-C sensors. Not usable on full-frame
Exposure
The quantity of light allowed to act on a photographic material; a product of the intensity (controlled by the lens opening) and the duration (controlled by the shutter speed or enlarging time) of light striking the film or paper.[Brightness/Darkness of the final photo]
Exposure Compensation
a technique for adjusting the exposure indicated by a photographic exposure meter, in consideration of factors that may cause the indicated exposure to result in a less-than-optimal image.[adjusting the brightness of an image with one move]
Fast lens
Refers to a lens that has a very wide aperture ... ie f/1.8 or f/2.8
Fill flash
A technique used to to brighten shadow areas by using a flash.
Fisheye Lens
Lens that gives a 180 degree field of view
Flare
Internal reflection or scrattering of light from the lens elements. Usually manifesting itself as a bright image region, and/or a reduction in contrast and saturation. Lens hoods are used to shade the lens.
Focal Length
The distance between the film and the optical center of the lens when the lens is focused on infinity. The focal length of the lens on most adjustable cameras is marked in millimeters on the lens mount.[the amount of zoom of the lens, more mm more zoom]
Focus
Adjustment of the distance setting on a lens to define the subject sharply.[sharpness]Focus Point(s)
The dots/boxes inside your viewfinder where you select the camera to focus at, can be set to manual or automatic.
Full Frame Sensor
Size of the sensor is the same as a 35mm Film Frame.
Graininess
The sand-like or granular appearance of a negative, print, or slide. Graininess becomes more pronounced with faster film and the degree of enlargement.[Pixel dots on image from film]
Grey card
Usually a flat card coloured neutral grey having a 18% reflectance across the visible spectrum. Used to provide a standard reference for exposure. Also used for white balance.
Histogram
A graph Showing you if the image is under/over exposed.
Hyperfocal distance
The focus point where all objects can be brought into acceptable focus up to infinity at a given aperture.
IF - rear or internal focusing
Focusing mechanism in which the front lens group is not moved.
ISO Speed
The emulsion speed (sensitivity) of the film as determined by the standards of the International Standards Organization. In these standards, both arithmetic (ASA) and logarithmic (DIN) speed values are expressed in a single ISO term. For example, a film with a speed of ISO 100/21° would have a speed of ASA 100 or 21 DIN.[sensitivity of sensor/film. Higher ISO Brighter exposure and more noise/grain]
Lens
One or more pieces of optical glass or similar material designed to collect and focus rays of light to form a sharp image on the film, paper, or projection screen.[The thing you mount on a dSLR]
Lens Shade/Hood
A collar or hood at the front of a lens that keeps unwanted light from striking the lens and causing image flare. May be attached or detachable, and should be sized to the particular lens to avoid vignetting.[The black thing on top of lens to block light entering from the sides of the lens, professionals put it on to make their lens look bigger :P]
Lens Speed
The largest lens opening (smallest f-number) at which a lens can be set. A fast lens transmits more light and has a larger opening than a slow lens.[See Aperture]
Looking Space
Commonly associated with portrait and automotive photography, also links in with "Rule of Thirds". Making sure your subject has looking space means to allow some blank space in front of your model or car's face for them or it to "look" into.[Also referred to as breathing space]
Macro Lens
A lens that provides continuous focusing from infinity to extreme close-ups, often to a reproduction ratio of 1:2 (half life-size) or 1:1 (life-size).[Lens to shoot really close, great for bugs and flowers]
Metering
Measurement of light on the subject using desired setting in camera or an external light meter. Helps determine exposure.
Monopod
A single leg usually used for heavier lenses while shooting for a long time. Used to take the weight off of one arm.Noise
Colorful dots you see on the photo when using too high of an ISO.
Normal Lens
A lens that makes the image in a photograph appear in perspective similar to that of the original scene. A normal lens has a shorter focal length and a wider field of view than a telephoto lens, and a longer focal length and narrower field of view than a wide-angle lens.[Usually a 50mm lens on a Full Frame Body]
Overexposure
A condition in which too much light reaches the film, producing a dense negative or a very light print or slide.[Too Bright]Panning
Using a longer exposure to show motion in a photo, usually used for fast moving objects like cars, sports players. Focus is on the subject and the background is "smeared".Post Processing
Editing.
Panning
A technique used to accentuate motion of a moving subject by following the motion of the subject (though the viewfinder) for the duration of the exposure.
Polarizing filter
Transmits light of a particular polarization while absorbing light that is of a perpendicular polarization. Light reflected by shiny materials is partly or fully polarized. Polarizing filters are turned to change the polarization direction.
Prime Lens
Lens that you can't zoom on, usually has great image quality.
Rule of Thirds
The common technique of putting the subject slightly off-centre, about a third of the way from either the left, right, upper or lower part of the photograph. Not always the best option, but generally can help a photograph's composition. [For example, if your subject was a tree, you might have the trunk a third of the way from the right-hand side of the viewfinder to help composition].
Stopping Down
Changing the lens aperture to a smaller opening; for example, from f/8 to f/11.[Changing the aperture down]Teleconverter
Something you mount between the lens to increase the focal length of a lens. Usually come in 1.4X and 2.0 flavors. The benefit is that you have a longer focal length without buying a new lens, the draw back is that you lose 1 stop of light with the 1.4X and 2 stops of light with the 2.0X.
Sync speed
Usually referred to as the maximum shutter speed usable for flash photography.
Telephoto lens
A long lens, usually above 70mm, also meaning the physical lens is shorter than it's focal length.Tripod
Three legged thing that you put your camera on. Used for heavy lenses or night shots to prevent motion shake.Vignetting
A fall-off in brightness at the edges of an image, slide, or print. Can be caused by poor lens design, using a lens hood not matched to the lens, or attaching too many filters to the front of the lens.[Black thing in the corners of photos]
Wide-Angle Lens
A lens that has a shorter focal length and a wider field of view (includes more subject area) than a normal lens.[What people call fisheye...and they are wrong]
White Balance
Color Temperature of the image. Setting depend on the lighting available.
Zoom Lens
A lens in which you adjust the focal length over a wide range. In effect, this gives you lenses of many focal lengths.[Not Prime lens]
Acronyms used on TPF
If I missed something tell me
f/#= f/ number/aperture
OOF= Out of Focus
PP= Post Processing
C&C= Critique and Comments
CC=Same as above
ROT= Rule of Thirds
TPF=The Photo Forum
IQ=Image Quality
PS=Photoshop
LR=Lightroom
IS=Image Stabilization(Canon) \
VR=Vibration Reduction(Nikon) -- These are all the same ;D
OS=Optical Stabilization(Sigma) /
AWB=Auto White Balance
CA=Chromatic
aberration
ETTL=Evaluative through-the-lens(Canon) \
iTTL=intelligent through-the-lens(Nikon) -- Also same thing
TTL=Through the lens
P&S=Point and Shoot
EXIF=Exchangeable image file format
SLR=Single Lens Reflex
HSM=Hyper-Sonic Motor (Sigma Lens)
USM=Ultrasonic Motor (Canon Lens)
VC=Vibration Compensation (Tamron Lens)
EOS=Electro-Optical System (Canon Camera series)
EF=Electro-Focus (Canon Lens)
EF-S=Same as EF, S stands for "short back focus" (Canon Lens)
If You have any other questions ask them.
Thanks, I think everything all ok
Very useful information for beginners like my self around here, thanks for putting it all together :thumbup::D
This is very useful! Thank you! Very excited to be a part of the community.
Follow me on instagram @jacksproxton
Ambient Light
Angle Of View
Aperture
Bokeh
Bracketing
Composition
Crop Factor Sensor
Cropping
Depth of Field
Digital lenses
Exposure
The quantity of light allowed to act on a photographic material; a product of the intensity (controlled by the lens opening) and the samsung mobiles duration (controlled by the shutter speed or enlarging time) of light striking the film or paper.[Brightness/Darkness of the final photo]
Fast lens
Fill flash
Fisheye Lens
Flare
Focal Length
Focus
Full Frame Sensor
Graininess
Grey card
Histogram
Hyperfocal distance
ISO Speed
The emulsion speed (sensitivity) of the film as determined by the standards of the International Standards Organization. In these standards, both arithmetic (ASA) and logarithmic (DIN) speed values mobiles prices in pakistan are expressed in a single ISO term. For example, a film with a speed of ISO 100/21° would have a speed of ASA 100 or 21 DIN.[sensitivity of sensor/film. Higher ISO Brighter exposure and more noise/grain]
Lens
Lens Shade/Hood
A collar or hood at the front of a lens that keeps unwanted light from striking the lens and causing image flare. May be attached or detachable, and should be sized to Nokia Mobiles prices the particular lens to avoid vignetting.[The black thing on top of lens to block light entering from the sides of the lens, professionals put it on to make their lens look bigger :P]
Lens Speed
Looking Space
Macro Lens
Metering
Monopod
Normal Lens
Overexposure
Using a longer exposure to show motion in a photo, usually used for fast moving objects like Mobiles prices Pakistan, sports players. Focus is on the subject and the background is "smeared".Post Processing
Editing.
Panning
Polarizing filter
Prime Lens
Rule of Thirds
The common technique of putting the subject slightly off-centre, about a third of the way from either the left, right, upper or lower part of the photograph. Not always the best free arcade gamesoption, but generally can help a photograph's composition. [For example, if your subject was a tree, you might have the trunk a third of the way from the right-hand side of the viewfinder to help composition].
Stopping Down
Sync speed
Telephoto lens
Wide-Angle Lens
White Balance
Zoom Lens
OOF= Out of Focus
PP= Post Processing
CC=Same as above
ROT= Rule of Thirds
TPF=The Photo Forum
IQ=Image Quality
PS=Photoshop
LR=Lightroom
CA=Chromatic
aberration
P&S=Point and Shoot
Thanks for sharing this information about TPF here, it ll help newbies like me!
This will come in handy for me. I will check back on this often lol
I have to learn all the terms and what they do so I know exactly what I am looking for while shooting.
Status
