Can someone help me with projection photography?
bekmeb
Lancashire
Hello, I'm doing an assignment for college and I wanted to project a striped and then a lace pattern over my subject. I used a projector and it worked but every time I captured the image it was far too dark to even be fixed by photoshop. This may sound a little stupid but how can I solve this?
I think I've attached it but yeah it was really dark you can barely distinguish anything.
Sorry I can't get it to upload but it was basically underexposed and too dark, you couldn't see anything. I used actual lace and strips of paper on a projector. Should I have had transparent paper and held it over the key light instead?
How are you metering?
Click here to learn how to post images.
Post one anyway... you'd be surprised what some folks here can 'read' in a photo.
Exposure triangle.
Shoot at a wider aperture.
Or... Shoot at a longer shutter speed.
Or... Shoot at a higher ISO.
Or... A combination of the above.
There it is. If your photos are too dark, it's not a lighting problem, it's an exposure problem.
Your projector could be the problem. What are you using?
skieur
Exposure triangle.
Thank-you very much I'll try that :) and I was just using a basic projector, I lay the lace/strips on the glass and it reflected onto the wall. Nothing special.
Get a piece of lace and hang it a few feet in front of an off camera flash.
Exposure triangle.
If you were using an overhead projector, it should have been reflected on a screen for greater brightness and then lights for overhead projectors also vary in strength and wattage. Some would be pretty weak.
skieur
