Canon Extender EF 2 x II
Tired but willin
Dartford, Kent, England
Hi there,
Can someone please confirm if you can use this extender for all Canon lenses'? I currently have the 17-85mm and 50mm Canon lens and am also thinking about buying the 55-200mm lens.....
Many thanks...
Dan.
Canon extenders (or teleconverters as everyone else calls them) will only fit select L lenses - is the white telephoto ones. This is because the front of each teleconverter has a protruding element and unless the lens it is being attached to has a recess in its base it simply will not fit.
So it won't fit any of the lenses you are talking about.
Some 3rd party options (kenko pro TCs and sigma) will fit more as they have smaller protrusions, but even then they come at a cost;
1.4TC all 1.4TCs lose 1 stop of light from the setup and degrade image quality- not horrifically though
2*TC all lose 2 stops of light and make a significant degradation to the image quality.
While Overread is correct, his explanation is a bit too far reaching in the way of image degradation. Perhaps a little more information on TC's would help.
TC's are designed to be used first on lenses with a focal length of 100mm or more. TC's are also designed to be used on prime lenses of high quality. They can be used on zoom lenses but they again need to be of high quality with focal lengths over 100mm. If you looked at the links I posted you will see that Canon's TC's only fit selected L lenses both primes and zoom. You will also notice that there are no primes under 100mm and the only zoom under 100mm is the 70-200.
TC's magnify the image of what ever lens it is on. Canon TC's will magnify either by 1.4X or 2X. When the TC magnifies the image that the lens sees it also magnifies the in problems that the lens has. If the lens is slightly soft, it will magnify that softness. So yes, it will degrade the image produced.
However, when a top quality TC is attached to a top quality lens you can get very usable image. I own both the Canon 1.4 and Canon 2X TC's and have no issues with using them. The only two lenses I use them on are my 300mm f2.8L and 400mm f2.8L. They are razor sharp lenses. The degradation the TC's may cause is very slight. Both the 1.4 and the 2X produce very usable images on both my 300mm and 400mm.
If you are interested in a TC I would offer two suggestions. First take you camera and the lenses you are interested in using it on to a good photography shop and take a few pictures with and without the TC you are interested in. Go home and take a look at the images they produce and decide if you are satisfied with the results.
Second, if you want that extra length, I would pass on the 55-200mm consumer grade lens and save up for one of the 70-200mm L lenses. The 1.4 works quite nicely on my 70-200 f2.8L. The 2X image quality on that lens is a bit less than I would want to use. Granted I rarely use this combination unless I happen to be in a situation where I don't have my 300 or 400 with my. My 70-200 goes about everywhere and my TC's are always in the bag as well.
Kenko's top of the line TC's are considered by many to be on par with the Canon TC's and will fit almost any Canon lens made. However, the same thing applies to the Kenko's as does the Canon's when it comes to light loss and image degradation. A top quality TC on a fair quality lens is still only going to produce fair to poor image results.
^ +1 This is a shot with the Kenko metioned above on a 300mmF2.8L
Would you STOP THAT!!! Always posting cool photos of road races and motorcycle races and such from the UK. All we have here is NASCAR. I mean like I wonder what they are going to do next? MAKE A LEFT TURN! :lmao: and repeat the process 2000 more times. :lol:
Great photo though.
Cheers i bought the Kenko with the intention of buying the Canon 2x (already got the 1.4) but the Kenko was so good and only £60 new off ebay Canon was £229 i didn't bother buying the Canon
Here's one with Canon 1.4X and Kenko 2X on the 300mm and focus still tracked
*insert really cool looking photo*
Great photo though.
You think you have problems - try lusting after that lens and living in the same country as him! :lol: The only thing that keeps me partly sane is that he only goes as far as dogs and horses - thankfully no foxes or otters!
Great photo though.
How about a Peregrine in the rain
Oh dear found a fox and an otter :lol:
Wonderful pictures, especially of the first bike, fox and otter - magic. Also thanks for the feedback on the lenses. I was looking to buy the 55-200mm but will hold off now and have a look at the 70-200mm, with the TCs a little later...
There is the 300mmF4L which is a great lens
