cptkid
- Joined
- Apr 13, 2013
- Messages
- 320
- Reaction score
- 71
- Location
- United Kingdom
- Can others edit my Photos
- Photos OK to edit
My two cents.
You talking sh*t.
End of discussion.
You talking sh*t.
End of discussion.
My two cents.
You talking sh*t.
End of discussion.
I'm going out on a limb here, but I'm guessing most folks on this forum are visually oriented. Because of that opinion and since there have not been any examples up to this point, please allow me.Don't crop in PP. Crop in camera. Otherwise, you produce crap.
It's a thing because not everyone agrees with it, actually. Saying "don't crop" is actually pretty much the same thing as "nail the exposure in camera", it's just a different dimension, and nobody gets all testy when someone says "You should try to get the exposure correct in the camera".
My two cents.
You talking sh*t.
End of discussion.
Who is
My two cents.
You talking sh*t.
End of discussion.
Who is
The OP.
I'll post an uncropped (to the best of my knowledge) of the DGN file from Bridge. I shot these last month. Let me back up slightly. My files are imported into LR3. There I will do a few certain tasks, not much and all edits are global in nature, but no cropping or tilt adjustments usually. I save the tilt adjustments unitl I open Bridge, since it is just as easy there. I save the crop tool for CS5. I'm by no means a PS guru and am pretty lazy for post work anyway, so most of the images I post haven't had a lot of time spent on them. Bridge gets the tilt corrected, WB treatment and the top few sliders tweaked. CS5 gets the curves adjustment, sharpening (USM or High Pass), CROPPED and resized. I'll stop here and admit that any prints to be made, which are not that many, gets a finer toothed comb ran through it.
Here's the DGN file resized for the web.
And here was my final result.
Did you notice how I turned a portrait oriented image into a landscape? Why would I do something as silly as that? Would you believe me if I told you the opposite method has also been done? Which image do you prefer? Oh behave, I'm not about to profess either is a great image, only for an example of why your above statement is filled with holes. If I bothered to run NR on it, perhaps it could be improved slightly. BTW, my cameras are only 12MP.
YMMV. Just my 2¢.
That is OK. We all have our likes and dislikes. HCB was the godfather of street work. Maybe you are a wizard as well as HCB, I don't know?
For me, I am on a much lower level. So, I crop 80% of my work or more. Not heavy crops, but yes sometimes heavy. If a crop has to be too much and the photo is bad quality from the crop, then it was not meant to be and trashed. That is my guideline for cropping...is it doable?
Ruining a photo due to dogmatic ego based determination is against my religion. I put image first, ego last. I try to be flexible. If people don't like my work becasue of cropping, no big deal. They will most likely not like the HDR as well. in the end we only have to please ourselves with our work. (Unless we are paid, then we must please the client.)
Using a rangefinder helps no end shooting on the street because you see more than just the frame
YMMV. Just my 2¢.
