photoguy99
- Joined
- Mar 20, 2014
- Messages
- 1,485
- Reaction score
- 313
- Banned
- #31
This is so delicious.
Village Idiot; the question was about depth of field, not the field of view.I think you are confusing DOF with FOV.You can also see how a full frame camera with the same lens on it will give you a wider depth of field at the same focal length.
If you adopt a more easily-understood terminology, yoiu would see that your answer confounds the original question and leads one down the wrong path.
Instead of using a term like WIDER to describe the DOF, use either DEEP or SHALLOW to describe the DOF. That way, the issue of lens focal length and sensor size will not enter the conversation needlessly.
There's a basic logic flaw in you're example. When you crop the image from the FF camera to compare it with the crop sensor camera then you're comparing a crop sensor camera with a crop sensor camera. To make an appropriate comparison you have to take the same photo with the two different format cameras. When you do that you'll discover that the format size does factor into the equation.
It makes no sense to compare two different photographs and then claim they share a characteristic nor does it make any sense to alter the function of one of the cameras (making them the same) and then claim they're the same.
To take the "same photograph" with two different format cameras you must use both cameras from the exact same position so that perspective remains the same. You should then equalize the FOV between the two systems and this will require using different lens focal lengths. At the same f/stop then the smaller format camera will produce more DOF.
The smaller the recording format gets the more DOF the system will produce as a general rule and vice versa.
The easiest way to look at that mathematically is to look at the formula for hyperfocal distance.
...........f ^ 2
H = ----------
...........NC
(H)hyperfocal distance = (f)focal length squared / N(f/stop) * C(circle of confusion). The value for circle of confusion is variable with the recording format. As the sensor or film size decreases the CoC decreases and that formula produces a different result moving the hyperfocal distance closer to the camera -- more DOF.
Joe
So which gives the wider DOF, FF or crop?????
Yes, but that is not what he asked.Village Idiot; the question was about depth of field, not the field of view.I think you are confusing DOF with FOV.You can also see how a full frame camera with the same lens on it will give you a wider depth of field at the same focal length.
But the sensor size, focal length, and FOV all contribute to the DOF size. WIDER DOF = DEEPER DOF and SHALLOWER DOF = NARROWER DOF.
Instead of asking about WIDER DOF, why not say "DEEPER"? That term is more in keeping with the physical manifestation of DOF, being as it is farther from or closer to the camera.
Now to rephrase your question: "So which gives the DEEPER DOF, FF or crop?????
(answer) Use the DOF calculator to find out for yourself. (Not that I don't want to do it, but your doing it yourself will show you better than anyone here can explain and you will see exactly how much it affects the DOF for a given lens focal length and distance.)
And it wasn't necessary, and served only to confound the issue.Told you...can of worms.![]()
How about just answering his question, as I did.
???This is so delicious.
.. one of the factors turns out to be sensor size, which I clearly did not understand. That discussion still pertains to the OP's question.
These explanations are always hilarious and worthless.
Go take a dozen photos.
Pick an object about four feet away. Take four photos of it. One with the aperture wide open. The next 3 or 4 clicks closed down. The next another 3 or 4 clicks. The last closed all the way down.
Pick an object about 10 feet away. Take the same four photos.
Pick an object 30 feet away. Again.
Now look at those dozen photos. Look at them. Really look.
Repeat for different focal lengths as necessary.
Now you know 1000x as much as any of these dumb threads will teach you.
Photography is about looking. It's not about calculating. It's not about using cool apps. It's not about following oft repeated rules and methods found on some god damned web site or in some ridiculous book.
LOOK shoot and LOOK.
