FITBMX
- Joined
- May 11, 2014
- Messages
- 3,860
- Reaction score
- 1,423
- Location
- Burns, KS, USA
- Can others edit my Photos
- Photos OK to edit
I am going to be taking some photo this weekend at an reunion Camp Quality Kansas > Home, I did this last year and it is in a huge "Gym" type of a building, with worthless lighting. Last year I only had a pop up flash, this year I have a speed light! But I have to have the light on camera because I will be moving around, however I don't want the light too direct.
I watched reviews on mini round soft boxes, they said even though they look dumb they work good. I didn't really have the money to put out right now (even though they are only 20 bucks) so I built one out of stuff I had laying around.
So here is how you can build your own!
I made circle 14" across out of black foam board (http://www.amazon.com/Elmers-Boards...UTF8&qid=1445457890&sr=8-1&keywords=foam+core) you could also use cardboard to save money, but I had this left over from something else. Then I cut a circle out of the middle of one, leaving a 1.25" edge.
The solid circle was then covered with heave aluminum tape (used for heater duct work it is expensive but I also had it on hand for some home repairs) you could also use tinfoil and glue it down, or chrome spray paint.
Using scrap pieces of foam board and cut into the right shape, I then glued them to the back to reinforce it.
Using some scrap felt cloth I got for free (but any cloth would work) , I cut a piece the circumference of the circle and around 4" wide. Using "thick" Superglue (Cyanoacrylate Adhesive, 1500cps) and standing the circle on edge I glued one end of the cloth to the edge of the circle. As I rolled the circle slowly down the cloth I put a drip of glue every inch to hold the cloth to the circle, I made sure to leave one inch of over hing off the back side of the circle to secure to the back later.
Using two boxes the approximate thickness of my light (2") to hold the front ring up to the right height, then gluing the felt down using more super glue. Making sure not to glue the cloth down or together at the seem, leaving a spot large enough for the light to fit.
Then wrap the edges around to the inside, and glue them like so.
I glued two "Tabs" of cloth that I then glued Velcro to, as you can see in the photos.
Using more foam board scrap, I cut four squires 2" in height to space the ring and the circle apart, and glued them in place.
I also lined the inside wall with aluminum tape, But I forgot to take a photo!
This is the one thing I did buy Nylon Rip Stop White Fabric for a diffuser, I used strait pins to hold it in place while I marked it.
I then cut it into a circle, and light melt the edges with matches keeping it from unraveling.
Using more super glue to install it to the front of the softbox. Glue isn't the best way, but it is cheap and works.
And pulled the felt cloth over the back edges, and it is done!!!!
This cost me around $2 to make, but a lot of that is because I had a lot of stuff already laying around left over from other projects. It should cost you around $5!
