Focus
pisto1981
Daventry
Hey all,
I got my new lense and decided to take some pics of a blackbird but as you can see, i'm struggerling to focus correctly
Ive got d3100 using AF-S Nikkor 55-300mm lense
Blackbird1 by Pisto1981, on Flickr
Here are my settings
settings by Pisto1981, on Flickr
Can you tell what im not doing right or do i just need to practice more? i noticed at 300mm the camera shakes alot. I have VR on
1/60 at 300mm handheld is very slow, even for VR (unless you have a real steady hand).
A simple rule of thumb is to use 1/focal length for your shutter speed at minimum (1/300 in your case). With VR on you could go lower but 1/60 really is pushing it.
What focus mode did you use? Did you use auto-focus or did you use a singe (or small group) of focus points? If you're on full auto-focus it could easily be that your focus is actually on the branch top-left (the one the bird sits on) rather then the bird itself... Looks a bit like that anyway.
Hi Judobreaker,
It was on single target focus. I had the camera in A setting so it choose the shutter speed for me. Am i right in saying that?
If thats the case and what your saying is needed, i need to switch to full on manual?
Manual still frightens to beejeebies out of me
Hi Judobreaker,
You can still use A you just need to watch your shutter speed and put your ISO up untill you get a fast enough shutter speed
Or you can use shutter priority with 1/250 shutter speed and let the camera choose the aperture. Bump the ISO to 800 and that would have given you 1/250 second shutter speed at f/8.
Thanks for the feed back peeps. will take it all on board
Some notes about VR from - Nikon VR explained - but read the details at the link too:
The first and most important rule of VR is this: never turn VR on unless it's actually needed.
Rule #2: VR should normally be off if your shutter speed is over 1/500.
Rule #3: If something is moving you, use Active. If it's just you moving the camera, use Normal.
Rule #4: If your subject is moving, you still need a shutter speed that will stop that movement.
And i've had VR on this whole time. Thanks KmH, will read your suggested article soon
