Fujifilm X-10: Lense compatibility question. Help Please!
gendarmee
Hi there,
Posting as I need to gift a a lense to friend who has a .Fujifilm X-10.
I've shortlisted FUJINON LENS XF55-200mmF3.5-4.8 R LM OIS and Fujinon XC50-230mmF4.5-6.7 OIS II Black.
I'm slightly confused as I am not clear on the lense compatibility of the lenses above. The cam says its an XT system but the lenses reads it X system. Confused I am.
Can any one confirm if either one are compatible?
Thanks a tonne!
Gendarmee
( when in doubt I could not help by remember this forum at first instant. Posting after almost 8 years.)
Both lenses you have selected are compatible with the XT-10. The XF series lenses are of higher build quality than the XC series lenses.
Joe
Joe
Thanks a tonne Ysarex for the uber prompt reply!
Will get the 55-200 for the better aperture range. Good to know about the build quality.
Many Thanks,
Gendarmee
Not all cameras called "Fujifilm X*" are part of the Fujifilm X system.
But those who are not are compact cameras, like the X100/X100s/X100t/X100f, X70, X10/X20/X30, XF10.
The camera you mentioned, the X10, is a compact camera.
The camera you linked, the X-T10, is a system camera and belongs to the Fujifilm X system.
Fujifilm has currently two camera systems, the X system using APS-C sensors (24x16mm), and the G system using crop medium format sensors (44x33mm).
The X lenses are called "Fujinon XF" or, for the cheap models, "Fujinon XC".
The G lenses are called "Fujinon GF".
There are also of course third party lenses for the Fujifilm X system, like Zeiss Touit (available for Sony E and Fujifilm X), or the Mitakon 35mm f0.95 (also available for Sony E and Fujifilm X). How those are called depends upon the company in question.
