fmw
- Joined
- Sep 30, 2006
- Messages
- 3,694
- Reaction score
- 493
We have some amazing photographic editors that provide the ability fix an image to look like we want it to. The point I'm going to make here is that you need to get it right in the camera if you want make the most of your post production effort with your editor. I gathered up some inexpensive amateur equipment and made some shots of the outdoor thermometer in my back yard to drive the point home. So that you know, the shots were made with a very inexpensive Nikon 55-200 f3.5-5.6 zoom lens and a Nikon D7000 camera. To start here is a shot of the thermometer taken at the 55mm setting on the lens.
What you see is what the camera produced without any editing. The subject (you can see it hanging from the tree) is well focused and well exposed. So let's crop down the image to include just the thermometer. Here is result with the image enlarged to around the size of the original photograph.
We were able to make an accurate shot of the overall image but there isn't much resolution in the thermometer itself. There is nothing we can do in post process to fix this. It is just short of pixels.
The next shot zooms the lens out to its maximum focal length of 200mm and even adds a cheap 1.4X teleconverter behind the lens.
The shot was made from the same location from the same tripod but you can see we have enlarged the thermometer quite a bit.
Now the thermometer cropped just like the image above is easy to see and can go to post production for final editing.
You can't put lipstick on a pig as they say or garbage in, garbage out. We want to envision how we want our final image to look before we fire the shutter. Use the equipment and technique you need to use to get as close to that as you can with your original composition and then fire the shutter. Get it right in the camera in the first place.
