- Joined
- Apr 4, 2011
- Messages
- 969
- Reaction score
- 228
- Location
- Holland
- Can others edit my Photos
- Photos OK to edit
What flash are you using with the camera? It looks kind of like a Vivitar 283, but I cannot be sure from the image.
Some older flashes dump the entire charge through the camera. This can damage some cameras, others protect against the full-current discharge.
Shoot some pictures without the flash. Sometimes- induced current finds it's way into digital electronics and has an affect on processing. Looking at the JPEG images, it looks like the image is corrupt- as in bits in the pixels either being stuck, or being dropped.
Seeing as the flash is visible in the image I'm going make the wild assumption that the flash was fired remotely.
I would like to see a remote flash frying up a camera because of full-current discharge.
This looks like a mighty fine in-camera processing problem to me.
Seeing as this doesn't happen with RAW I'd suspect the in-camera JPG processing.
This pattern repeats itself every 8 pixels, that's one heck of a nice computer number for ya (2 to the power of 3, also happens to be the length of one bit).
Have you tried adjusting the JPG quality to see what happens? It might be that adjusting the quality causes the processing to skip a process or do it differently which could make the problem disappear.
If that doesn't help you could also try to upgrade the firmware... If there's a software problem somewhere it might be fixed that way.
I'll ask my dad if he has an idea tomorrow, his job is hard-core image processing (like automatically analyzing security-camera footage kind of processing). He might just have some more ideas.
However, if a firmware update won't work I'm thinking this might be a problem you can't fix which would mean sending it back to Nikon for repairs or replacement.
Remember that the Vivitar 283 has an off-flash sensor that connects to the camera's Hot Shoe and can be used remotely, AND dump the whole capacitor through the camera. The sensor unplugs from the flash, plugs into a special shoe that goes on the camera, and the cord plugs into the socket of the flash. The capacitor dumps through the cord, into the camera. Never put your finger over the PC socket of the camera if it has both a hot shoe and PC socket.
Send me your camera, and I will arrange for a Demo.
Ok, I'm not familiar with that kind of flash so I guess it is possible to get that current into the camera. However, if that would be the case we're talking about a hardware issue and then you'd expect RAW files to be affected just as much as JPG files.
