Whoever said with ETTL the flash goes lower than 1/128 has no idea what they're talking about. Sorry its just the wrong information.
When you need to squeeze every very bit of power from your Speedlite, switch it to Manual mode and set it to 1/1. In E-TTL, the Speedlite uses a bit of its power for the pre-flash. By switching to Manual, you eliminate the pre-flash and send all the juice straight out in one big burst.
Conversely, if you are shooting in Manual at the lowest power setting and still have too much light, switch over to E-TTL. The pre-flash will suck up a bit of power and thereby reduce the intensity of the flash. The change will be small, but it might be just enough.
and no Kundalini, if the subject is away from background then the shutter speed/iso won't matter UNLESS shutter speed is ridiculously low and ISO is extremely high. When using flash, the flash will be same intensity on the subject at 1/125 shutter speed vs 1/160 shutter speed. The flash doesn't doesn't stay open enough to matter. Same with 400 ISO or 800 ISO. ONLY thing will change is the ambient light being darker vs brighter. (please don't start an argument with me saying I don't know what I'm talking about)
