I will c&c your work for you, beginners welcomed.
How about this:
good
-great side lighting
-good off center comp
-good DOF
-good detail
nit
-photo is overexposed (clipping)
-crack in the pavement is a bit of a distraction
-good comp but the ball is to close to the edge of the photo on the left
-photo is a tad flat (contrast)
-photo is a tad soft
tweak
-darkened (burn) around the BG of the ball to create more light drama
and to improve overall exposure
-lightened (dodge) the lit side of the ball to create more light drama
-added a tad of global contrast boost
-added a tad of selective USM (sharpening) to just the ball
-healed out the crack in the pavement
Hope this helps and thanks for posting.
Take care,
Dwayne Oakes
This thread is so much fun, thanks so much Dwayne, I will see what I want to post :D
Don't know what to do with this one, especially with the background.
Thanks for taking a look
good
-great off center comp and sky to 1/3 rule
-great light
-exposure is good
-nice waves
-good DOF
nit
-WB (white balance) is a tad on the cool side (blue color cast) personal
choice
-photo is flat (lacks contrast)
-photo is soft
-dark band in the upper right corner is a bit of a distraction
tweak
-set the WB (white balance) to a warmer setting to remove the
blue color cast (personal choice)
-moved the blackpoint slider and midtone slider in (levels) to the right a tad
to darken the photo, this will give the photo a little dynamic range boost
-darkened (burn) the sky on the right to create more drama
-lightened (dodge) the water spray coming off the waves under the pier
-lightened (dodge) the one pier light that is lit
-lightened (dodge) the some of the water in the FG
-added a tad of global color saturation
-added a tad of global USM (sharpening)
-healed out the dark ban in the top right corner
Take care,
Dwayne Oakes
Wow, this thread is inspirational, learning the craft and would appreciate your critique
SouthFreo... that's hot!
good
-beautiful capture
-great pose
-great highlight control (no clipping)
-exposure is right on
-good DOF
-great colors and contrast
nit
-to much clutter
-photo has a tilt to the left when placed on a grid
-photo is a tad noisy at 100% crop (walls)
tweak
-straightened the photo
-cropped the photo tighter to get rid of the clutter
-used gaussian blur (soft-focus) tool around the edges of the photo
-put the photo through NR software
-healed out the shirt of the chair on the left
-healed out the door knob and string on the right
-healed out the door hinge on the right
-healed out the blue object on the top self in the center
-put a frame around the photo from a plug-in from Ulead PhotoImpact 12
software.
Take care,
Dwayne Oakes
Great thread. I downloaded Photoshop and found it to be completely overwhelming. Here is what I consider to be my best photo so far.
Thank you very much for the comments !
good
-cool 8mm angle
-great color and contrast
-very good detail
-good DOF
-low noise
nit
-street light on the left is a bit of a distraction
-dark spot in the bottom left corner could be cropped out
-photo has a slight tilt to the left
-unqual space on the sides (comp)
tweak
-cropped the photo so there is equal space on both sides of the photo this
will also got rid of the dark spot in the bottom left corner
-added a tad of selective color saturation to the teal color light in one of the
arches on the right
-added tad of global contrast boost
-healed out the street lamp on the left
Take care,
Dwayne Oakes
Thanks Dwayne, great comments and advice.
A friend and I enjoying a hike yesterday.
good
-great place
-very good comp
-no sensor dust (sky)
-great DOF
nit
-exposure is about right but some clipping in the FG
-colors and contrast are a tad flat (typical due to the harsh light)
tweak
-cropped out the black border not because it does not look
nice but because it will get in the way of the healing out FG step
-darkened (burn) the sky a tad to improve its color saturation
-added a tad of selective contrast boost to just the green mountain range
in the MG to cut through some of the haze
-added selective color saturation to just the orange color in the two
mountain peaks on the right
-added a tad of selective color saturation to the red stripe on the shoe
-healed out the hotspots (clipped) areas in the FG
-darkened (burn) the FG to tone it down a tad
-added a tad of selective USM (sharpening) to just the mountain range
-healed out the white spot on the mountain range on the right
Take care,
Dwayne Oakes
THANK YOU.... Those mountains are full of Iron, so hence that color, and you helped really bring it out. Those selective enhancements really come out nice.
Initially I had trouble with the shot because the foreground is actually a glacier.. a bit dirty, but still had clean parts that REALLY shine in the bright sun. I like the way you made it even and not eye intrusive.
Thanks again!
