- Joined
- Aug 15, 2013
- Messages
- 13,695
- Reaction score
- 3,369
- Location
- SE Michigan
- Can others edit my Photos
- Photos OK to edit
Cataloging and culling example.
If I have 500 pictures from a day of shooting, I import into a folder by date with appropriate tags.
In Library grid mode select all, then give them 2 stars.
Then I set filter to view only those greater than or equal to 2
I go through them individually hitting 1 for each picture I want to delete and it disappears from view.
For potentially good pictures, I hit 3 or 4
After finishing the pass through, I set filter to allow only =1 and review them to make certain I didn't mark anything for deletion that I really want to keep.
Then select all the 1's in library grid mode and delete
another method ... in Develop mode
I use "X" which is mark for Deletion
Then under the Photo menu option, I think the last menu selection, is Delete Rejected Photos (or something like that).
Overall, when I go through the photos (using my keyboard arrows while I do some initial tweaks to see if I like them) I mark them "X" for deletion, "P" for flagged or nothing if I'm unsure.
Then I use the Delete Rejected Photos to remove them entirely from disk.
Then as I continue my post processing I may use the stars if I really like something to identify it above the others and modify any "P" flagged or "U" unflag it
Then I set the filter to Flagged for the photos I like, Select them all and export to JPG.
multiple ways of skinning the perverbial cat ...
