ntz
- Joined
- Oct 29, 2020
- Messages
- 716
- Reaction score
- 388
- Location
- Central Bohemian, Czech Republic
- Can others edit my Photos
- Photos OK to edit
@jeffashman - using ISO should be based on know-your-camera basis .. I don't want to interfere with anybody else making input into this thread so everything I said is my personal opinion and my way of doing things ..
it depends on what you're shooting ... I recommend not using automatic ISO and if you do (while shooting sports or wildlife) I'd recommend to have set the upper limit to max acceptable ISO value based on current conditions and your knowledge of performance of your camera ..
for example with my APS-C Nikon (crop factor is 1.5, so the ISO performance is 1.5**2 lower than with crop factor 1.0 aka FX -- eg. now simplifying that but my performance with ISO 100 is eq~ to ISO 225 on full frame - 100 * 1.5**2) I have 99% of my photos < ISO 800 .. of course depends on what you're shooting .. for wildlife and sports in the daylight I use ISO 200-500 with my f/4 telephoto lens .. when I would be shooting in the really low light conditions like for example in club, I wouldn't want to have ISO higher than say 1600, it will will severely affect the photos ... as I said earlier, I tend to shoot 99% of time in A mode and I am changing my ISO manually to have maximum control over it ... Also I use an exposure correction instead of manual mode
Thank you! All of this is very helpful, and I am learning, so it is all good. So, which is better? Ceske Budejovice, or Pilsner Urquell? [emoji16] Zdravim! [emoji482] Or is there something better that I haven’t discovered yet? [emoji16]
Sent from my iPhone using Tapatalk
Hey Jeff
there are myriads of boats and vessels on the lagune with the most prominent flagships that are indeed Pilsner Urquell and Budweiser Budvar .. Worth to note, that these two main flagships are usually fiercest antagonists in here, rivalry not only on the field of taprooms but also on the tongues and throats of drinkers ... Pilsner crowd says that B is too sweet and heavy and will make you a headache and Budweiser crowd says that Pilsner doesn't even taste like typical Czech beer because it's so over-manufactured and special.
Amongst smaller vessels, there are true gems as well as decks which you'd rather like to avoid. What is popular in here in past decade is the boom with mini-breweries which brew usually untypical kinds like IPA and ALE .. Also worth to note, that Bohemian breweries are much better and safe than most eastern Moravian and Silesian breweries ..
I wish you great golden light on your photography hikes !!
regards, ~dan
