Leitz Focomat V35 Enlarger
sciolist
North Carolina
I've acquired a Leitz Focomat V35 enlarger and found the head/film carrier/lens is several degrees out of parallel with the baseboard (the front of the head is nearer the baseboard than the rear). Before I attempt to correct this, I thought I'd ask if anyone has done it successfully.
If there's no adjustment in the column/base, then just shim the base. A machinist's level and a precision square should be all you need.
Thanks for the replies. The misalignment is significant and would require much shimming to correct - an inelegant work-around. The issue isn't addressed in the manual as far as I can tell. I suppose Leitz didn't envision users tinkering with the enlarger to correct what was surely a factory setting.
