- Joined
- May 1, 2008
- Messages
- 25,507
- Reaction score
- 5,113
- Location
- UK - England
- Can others edit my Photos
- Photos OK to edit
- Moderator 🛠️
- #31
Tripod wise a 055XPROB or the older model (second hand now mostly) from Manfrotto is a good budget starting point for a solid tripod. However I would urge you not to skimp on tripods and to save up and get a really good set of legs since a good set will last you decades. Also if you plan on doing a lot of walking with the tripod a carbon firbre is the ideal solution - they cost a lot more but are lighter!
As for a tripod head for macro a ballhead is not what you want. Even the top range ball heads can suffer from creeping which is not noticable normally, but at macro magnifications it quickly becomes a pain. A good 3way head is a good setup up but idealy you want fine control in each axis and you only get that from a geared head. The manfrotto junior geared head is a very popular choice for this - I know its certainly not a budget line option, but for macro its the head you want to aim for (its also good for any other static* subject like buildings, products, landscapes etc... but hopeless for a moving subject like birds, pets kids or sports - which is where a ballhead excells).
*note I said static subjects whilst refrencing insects - if you are using a tripod for an insect shot you need one of two things - either a cold insect which is not moving very much (early mornings and just after rainstorms are when to find cold and slow insects); or a lure (rotting fruit, sugar water, flowers) so that the insects come to a controled location where you are setup.
If you are tracking an active and awake subject the tripod is not help at all since you will never have time to setup - here is where flash and monopods are what you need (though I have to admit I have not got used to using a monopod -most don't go down low enough for my tastes).
