Monopods
myko5
CNY
I was wondering what the differences in monopods I should look for. To me I think its just a pole with a head for a lens ring to attach to. Is there really anything I should look for other then height and weight? I wouldn't be using it professionally. After getting my 70-200 2.8 and realizing its weight, I just thought one might be handy to have for little league games and sports of that nature.
Any help is appreciated. Thanks.
Get one that's tall enough you can look into the VF without bending over.
I would also suggest getting one with a tilting head rathr than just a flat plate. This will make it much easier to adjust your vertical axis for those pop-fly shots and long slides into home.
Far as I know most monopods have a flat top - the head with the tilt is an extra (many shops sell both as a kit though).
Yea browsing thru b&h I noticed the kits with the different head on them. Cheaper then I expected, but then again I dont really know the difference in brands too well.
Thanks for the tips.
Although there are monopod heads available that can tilt from side to side only, I opted to put a full ball head on mine. That way, I can be in any position relative to the subject, with the monopod at (slightly) other than true vertical, and still get the shot the way I want it.
A small ball head is a good idea. Since a monopod is something you would carry when you don't want to or can't bring a tripod, probably its most vital features are that it folds up to a pretty short length (mine fits in my regular backpack) and it's not too heavy, otherwise you will not want to carry it and won't have it available.
Make sure you have a quick release if you're hiking! It's a pain to keep having to unscrew it. Tilt-head is probably the way to go if you need a head.
