Shaylou
I saw your Flickr images, quite stunning, great work! But which of those would you copy for a Senior Shoot, I couldn't find one.
There is a shot that is a young couple in a gazebo that I shot from the ground looking up. That's a start, you see my point was to try to concentrate on the composition and this will lead to a better image. It's not about copying as much as it is about looking at others work to stimulate your own imagination. I could probably point out 5 or 6 shots from there that I saw someone else do something similar and wanted to put my own twist on it. One thing you might check out is leading lines. They are great for adding interest to a photo. When i saw the shots by the fence the first thought was (i would of used the fence as leading lines). Like you, I am a student of photography and probably always will be. I am becoming fascinated with composition and now see why the pros always suggest studying it. I hope I have explained myself clearly. Good luck.
