my first portrait in natural light, C&C please!
Miti
Nuoro, Sardinia, Italy
Hi everyone!
This my first try taking pics in natural light. I shot in jpeg not raw by mistake. I don't know very well my my camera yet so I always forget something while shooting...:D
I came too late to photography I guess.
Canon 550D, EF 100L macro, f/2.8, iso 100, at 17h PM.
Looks like WB is off.. he is very yellow.
Yes it looks that way to me, too. But is there any pos to be changed in pp if it's a jpeg pic?
You can't alter WB if you shot it a.jpg but you can color correct. WB/Tone is definitely off, otherwise it's ok but why a square crop?
The pose has his shoulders a little to square to the camera.
The kicker lighting from the back left and right works well, but his facial mask is a bit under exposed.
The white balance looks off a bit since his skin tone looks to have a decidedly yellow cast to it.
I did an edit by adjusting the white balance (ACR temp/tone sliders), added some exposure to his face, a mid-tone contrast boost, some eye work, some local sharpening, a crop to get rid of some background distractions-
Thanks KmH. That's a lot better. In order to have his facial mask correct exposed should I have to use a reflector or flash through an umbrella?
Or just expose for the face ;)
As Trever1t alludes to, you can expose for the face by using Spot metering mode. Partial, or Center-Weighted metering mode might also be used.
I suspect your camera was set to what Canon calls Evaluative metering mode, and Nikon calls Matrix metering mode.
Yes a reflector and/or fill flash would have helped. A key concern is getting light to the eyes, but not so much light that the person starts to squint. An issue I usually have with using available light is a lack of directional control and strength.
To help prevent squinting or blinking, manually controlled flash is the way to go. TTL flash has to use pre-flashes which often causes people to blink.
Thanks KmH for your precious counsels. I didn't get it what Trever1t was alluding to. Yes my camera was set to Evaluative mode.
With regard to WB what would you advise a newbie like me: use a grey card or correcting in post? I mean which is easier as well...:D
