Need some good advice!!!
tlsavage
Pennsylvania
Hi everyone! I'm looking for advice from all of you. I have had a passion for photography since high school (I'm now 31) and am now wanting to truly learn!! I have a Nikon D2X - it was a gift and I love it, I just really have no idea what I'm doing with it! I have used it - on automatic- forever and am becoming more and more disappointed in my photos. I have been looking at different online schools but then I read posts stating the schools are a waste of time. I've tried reading books but it's not sticking. I need to actually see it done and then do it myself. Anyway, I am asking if you have any recommendations for learning the basics (and then more) so I can get out of automatic? Thanks in advance!!
........ Anyway, I am asking if you have any recommendations for learning the basics (and then more) so I can get out of automatic? Thanks in advance!!
Post a photo, and why you don't think it 'came out'. We'll go from there.
YouTube videos are a great resource, but probably your best bet would be to join a local camera club; there are always members who enjoy working with those who want to learn.
That's what I was gonna say. YouTube has been a great friend to me, and I've learned a ton by reading tutorials online. I will print out tips and stuff and keep them with me when shooting. And I've learned the most by posting photos here and getting critique. Learn from mistakes!
These are some photos I took of my daughter outside. The ones that I really liked were blurred. The other photos were taken on a day trip to NYC - the coloring is all off and just all together look bad.
These were from a graduation - inside.
The ones of your daughter are soft because you missed the focus. Not sure if you're using AF or not.
The last two are underexposed. Shooting in manual doesn't mean you just get to pick whatever settings you want.... they (ISO, shutter speed and aperture) all must 'balance out' to get a proper exposure.
Outside of the flash, they're all 2 or 3 stops underexposed.
Are you looking at the on-camera meter before taking the shot, and checking the histogram afterwards?
Thank you... I don't know how to shoot in manual. That is why I was asking for advice as to what school/on line seminars/etc are the most recommended. I don't want to spend a ton of money on a school that is not worth the time. Thanks again!!!
The camera has a light meter built into it. Check the manual to see how to read it. That will be the first step in getting correctly-exposed images.
You wanted good advice, and you came to the internet? Gutsy move.. lol
Ok, but in all seriousness, I'd recommend you start with aperture priority mode. Makes it very easy to adjust your settings to get proper exposure and still control both your aperture and ISO for the kind of effects you want. I use it quite a bit myself, I find it very easy to adjust my settings quickly and since I mostly shoot wildlife that can be a very important consideration at times.
I looked at the EXIF data for three of the shots of your daughter...EXIF said all three were shot in Manual exposure mode, at 1/125 second. Overall, your pictures look under-exposed for the most part. I've owned a D2x since May of 2005...when used properly, it's a good camera, but it's also kind of a temperamental camera as well. It's EASY to get bad results from the D2x.
Some good instruction would help. You do seem to be making some fundamentals errors. Like the shots of your daughter...1/125 second shutter speed has caused her to blur quite a bit due to movement in several of the frames, and the focus was missed a bit in a couple more.
It's all about light...getting the amount of light you need, in the time period allotted, and the sensor as 'sensitive' as needed. More specifcally, it's the photography exposure triangle...aperture, shutter speed and ISO speed.
Although there are many possible combinations of the parts of the triangle that will produce a 'correct exposure', deciding what to increase with offsetting decrease(s) in the other 1 or 2 to get the picture you want is a matter of tradeoffs. Which of the three settings are 'required'...say shutter speed 1/125th or faster to capture human subjects at walking speed or slower without a blur. But sometimes 1/200th might be needed to completely 'freeze' them if walking fast with swinging arms. But to use that shutter speed and still get a good exposure will require either increases in aperture size (f-numbers -they are actually 1/fractions, with the 1/ part omitted - and smaller numbers are larger aperture sizes) and/or increasing the ISO speed (sensitivity). Increasing the aperture size results in a 'thinner' depth of field. Beyond that, things will be increasingly blurred. See Understanding Depth of Field in Photography for a good DOF tutorial. Increasing the ISO speed, the speed at which the camera sensor 'reacts' (records) the incoming light works to a point. But above, say, ISO 1600 might result in numerous small colored dots in the resultant picture, particularly in the darker areas. That's called 'noise'. While in-camera software will automatically correct some or all of the noise, at some point, it can't correct it all without losing some sharpness.
So, it comes down to tradeoffs. When shooting in manual mode, I typically think of what setting is required to get my shot, and what compromises on the other two am I willing to make to get that shot. Many times, like outside on a sunny day, there's still a lot of leeway in the other two settings and still get a good shot...good DOF and slow enough ISO to not have any noticable noise.
But don't think you HAVE to shoot in manual mode. "A" is a good starting point, but when the camera doesn't automatically produce the desired exposure (too slow a shutter speed causing subject blurring indoors is a common "A" problem), then it's time to start learning to use the P setting (I think that's what it's called on a Nikon) where you can make a setting or two, and the camera will automatically determine the other(s) when the picture is taken. Then there's the time when you might want to photograph race cars, or a high speed toddler running around. That's when you'll want to force the camera to lock in a fast-enough shutter speed like 1/500 to stop the motion by using Tv mode. And on and on.
A couple of months ago, someone here coined the phrase 'acceptable compromise' when deciding what settings to use on their camera. I can't think of a better description. What are you willing to 'trade' to get what you want?
Some schools such as trade schools, community colleges, the art councel in Gettysburg provides a few courses in the evenings. Check the local news papers for adult education classes. Also organizations such as National Geographic may hold week end seminars in your area which are generally suitable for most levels of ability. I got started in the mid 70's with a trade school evening course and a week end seminar from National Geography. The trade school provided very basic information Nat Geo's instructor was wildlife the instructor did a lot of their bird photos and showed how he set up feeding stations to attract different birds. I have since taken additional wildlife and landscape photo courses.
