Hi All,
I'll keep it brief,
My Minolta XGM (1982) has underexposed a new, ISO 200 36 exp. Kodacolor roll (it's first roll in 10 years), 100% consistently - by around 1 stop. Film technology presumably has improved and as such 200 ISO is the new 100? I'm considering setting the ISO to 100 on the device, as this will likely resolve the issue.
Guidance?
YES, it has long been quite common to over-expose color negative film, which likes a "generous" exposure,much more so than say, color slide film. If results are generally consistently looking under-exposed, I would down-rate the ISO of the 200 speed film to 100, or maybe even to ISO 80.
Check the camera first, and make sure the Exposure Compensation dial is not already set to say, Minus 1.0. Instead of making the change using the exposure comp dial, I say
down-rate the ISO right from the get-go, and THEN use the Exposure Comp dial for situations where you need or want to dial in EX, such as say + 1.7 EV for strroingly back-lighted subjects in shade.
We used to shoot Kodak VPS color neg, nominally rated as ASA 160 at the time it was made (before ISO, so save any arguments) as if it were ASA 100; I shot hundrerd and hunbred of rolls of Kodacolor Gold 200 at ASA 100 or ASA 125; I shout THOUSANDS of slide photos goinjg the opposite way, rating Kodachrome 64 at ASA 80 or ASA 100. Generously exposing modern color neg films usually results in better shadow detail, and finer grain, and better images! (this has been commonly known for 40 years regarding how to expose color neg stocks.)
Sometimes exposure issues result from how one uses the camera's built-in meter, and so this is why I suggest just down-rating the ISO that full stop, from 200 to 100 ISO, in ortder to get the meter's readings more in-line with where the actual expiosures need to be,
