I have to disagree with KmH, primes are still much better optically than zooms. The gap is closer than it used to be, and the price of the lens is a factor, but most primes still outperform most zooms. And, at a given price point, I would be amazed to find a zoom that outperformed a well designed prime. If you can spend $2500 on a zoom lens, then it might _rival_ the quality of some $500 and $1000 primes, others will still outperform it hands down. The bokeh on a prime is pretty much always better than the bokeh from a zoom (unless of course you're comparing a $100 prime to $2500 zoom or something silly).
It's also common for some people to recommend against 1.4s and 1.8s for n00bs. Again, I disagree with this. That's like saying don't buy an oven that you can turn up to 500 degrees because you'll burn your casserole... what happens when you want pizza?
The DOF at 1.4 and 1.8 is quite thin (if you're close to your subject... if you're not that close, then it is not that thin). As a result, you will need to focus more accurately in order to place the plane of focus where you want it. You might miss focus a few times before you get the hang of it. It simply means you'll need a little practice to get the most out of it (like any other piece of gear). Recommending that beginners avoid fast primes because they might have to learn something is flat out bad advice. Additionally, you can stop down to 2.8, and it will be as easy to focus as any zoom lens, but it will likely be sharper and less distorted than any zoom lens that isn't much more expensive.
When you do learn to shoot at 1.4 (doesn't really take long if you pay attention), you have much more creative flexibility, because you have more options for depth of field, and better ability to shoot in low light.
