Thanks for the reply Tim (& I like your Flickr)! So you think the 11-16, 35, 50, and 85 would make a good set for my uses? Being in college, the 70-200 would be way down the line. The one thing I've heard is that the 35 and 50 is an either/or purchase and the 50 and 85 is the same.
I might just go straight for the 85mm 1.8 or 1.4, and then fill in the 50mm and 70-200mm eventually. Oh, another thing I forgot to mention: I'm on the brink of starting a DSLR cinema class...no VR on any of the fixed lenses, correct? Is there any way I can get by without VR, or should I swoop one up? I'll be doing mostly stills after this class, so it's not like I need a video arsenal.
I depend a lot on my 70-200 f/2.8 VRII for my portraiture and when I require images to be sharp; but my 85mm f/1.8 is way lighter and more fun to use if I'm gonna be taking pictures for a whole day.Personally wouldn't be without my 70-200 for my FF and my APS-C. Sharp as a tack no matter what I put it on.
Tamron 16-300 is for you.
Ideal to test out which focal length you like the best.
As long as you're not a pixel peeper or need to provide files that get printed at billboard sizes, that lens will do fine.
At short focal lengths VR really isn't a feature that most folks actually use that much, if your shooting at shutter speeds equal to or higher than your focal length that's usually enough to eliminate camera shake. So unless your shooting at very slow shutter speeds you probably won't notice a lack of VR.
Primes are nice but honestly for what you've described I'd probably look for a decent zoom. The 7100 has a built in focus motor so you could get an older Tamron zoom pretty cheap, something like a 28-75mm 2.8 would probably be a great addition to your bag. It would give you a bit of zoom when needed but still be versatile enough in most other situations and I can tell you from experience the IQ is excellent.
Define large? and how close will the viewer be?I've had to turn in some pretty large prints, so that's why I was questioning if it would be most reasonable to assemble primes vs zooms. I'll check it out though!
Why would it matter if the prime was designed for and FX or DX image projection?
Price? or FOV?
