Nikkor lenses, need professional advice
I'd go for the 50mm 1.4G over the 1.4D if you could, the 85 1.8 is an amazing lens stopped down past f/2.8, the 28mm f/2.8 is OK, go for the 35mm f/1.8 or 24mm f/2.8 instead.
for DX though, look into the tamron 17-50 f/2.8 + 85mm f/1.8D and call it good. That way you have a somewhat fast normal and a fast portrait tele.
Wait.. so are you saying to get the 24mm f/2.8 instead of the 28mm? and still get the 50mm and 85mm? Or should I get the 24mm f/2.8 35mm f/2.8 and 85mm f/1.8?
Thanks everybody for the input!!
i'm saying skip the f/2.8 primes, save some money and get a 17-50 f/2.8 + 85mm f/1.8 instead.
Which 17-50 f/2.8 are those pictures from? I'm guessing the older non VC model, since you've had it for 3 years..?
Yep non-VC BiM version which has the built in motor for AF on D40,D60 type entry cameras.
Thanks Derrel I Strive to always try! That's the best I can do.
