- Joined
- Aug 15, 2013
- Messages
- 13,695
- Reaction score
- 3,369
- Location
- SE Michigan
- Can others edit my Photos
- Photos OK to edit
Well I went out today for a test shoot of a soccer team that I used to coach using my d600 instead of the d7000. It went okay, though I have to shoot a little before what I used too - according to memory. basically a split second quicker of when I press the shutter than compared to the d7000, at least it seems that way. And it's slower FPS .. easily recognizable.
But after half time I went to go shoot again and my focus point would NOT MOVE (using d9, and you use the pad selector to move the focus points). I thought it may have been my change of lens but nope, put it back on/off, switched lenses. Power On/Off, etc NOTHING. Oddly you could still scrolls through the menus using the pad selector.
It drove me nuts for a bit. I could have moved to the other side of the field and all would have been well for the action flow. But I wanted my focus point to MOVE.
So I packed up and drove home. Thinking, well, I guess I'll just use my d7000 body as my 600 is now BROKEN.
Well I got home looked at the camera, swapped lenses, nothing.
Since I was at my wits end, I did the one dreaded thing that NO photographer wants to do
I don't think they'll kick me out of this forum for this hideous act.
Yes, take your face out of your hands now and stop crying. It's not that bad as it's only a TEST.
AUTO Mode.
Yes, I succumbed to putting the camera in AUTO.
And I noticed that in auto the camera moved the focus points to where it thought it should be.
Well, I then knew that the focusing system was still operational.
Guess I could have done that by putting the focusing system in AUTO instead of the entire camera eh ? ("eh" - in a canadian bacon type accent)
Then I noticed that the Focus LOCK is surrounding the pad where as on the d7000 it is a separate switch below the pad.
And it was on "L"
Gosh gollee ... I locked the focus point and never knew it.
I've never used Focus Lock before on the d7000. NEVER !!
And on the d7000 it is a harder switch to move and it's out of the way. On the d600 it's now a lighter action switch and RIGHT there with the THUMB.
So now I have to remember that if the focus point ISN'T moving with the pad selector that the lock is ON.
What they need is a Focus Lock selector switch lock for the focus selector lock switch.
mark this one on OPERATOR ERROR
DUH
If anyone wants to donate to the cause of photographer literacy send money to TPSKLC, Detroit Michigan .. The Photographers Soup Kitchen Learning Center
now go back out and shoot.
AUTO Mode.
And it was on "L"
DUH
