The new g version has significantly better image quality--it's sharp and contrasty wide open, whereas the older af-d needs to be stopped down to f2.8 to achieve the same quality the g has at f1.8. Even the expensive 1.4g can't compete with the 1.8g below f2.8.This is due to the 1.4g and 1,8 af-d being based on an ancient lens design whereas the 1.8g is newly designed with an aspherical element.As for working on film cameras the g will work on all autofocus nikon film cameras with a few very rare exceptions.
Ken Rockwell said:This new 50/1.8 G has a moderate amount of barrel distortion, while all the other the 50mm f/1.8 lenses, especially the 50/1.8 AF-D which sells today for half the price, has none.
The earlier Nikon 50mm f/1.8 AF-D costs about half as much, has none of the distortion, focuses just as close and fast, is just as super-sharp at normal
apertures, stops down to f/22 instead of being limited to f/16, and weighs much less. Although the older 50/1.8 isn't quite as sharp in the corners at f/1.8
(who cares), it is just as sharp in the center
On AF cameras older than about 1990 and on manual-focus 35mm cameras, this G lens won't work at all.
First off, the 1.8D will work on film cameras, the 1.8G will not.
Ken Rockwell focuses on linear distortion to an absurd degree. First off, if distortion is "simple", which is normally will be on ANY normal or telephoto lens design, and not complex, like moustache disortion, it is EASILY eliminated in software. I am not sure why Ken focuses on distortion so,so,so much--most people will not see distortion, unless they shoot a lot of architectural studies or brick walls or test charts, so to me it seems like Ken likes to whine about a non-issue all the time. What most people WILL HOWEVER be able to spot is crappy sharpness or low contrast or veiling softness when a 50mm lens is shot wide-open to perhaps closed down one stop from maximum aperture. I'm not a big fan of using a 50mm lens at f/1.4 or f/1.8 or even f/2 or f/2.8, but if the 50mm 1.8 AF-S G is really good optically at the wide apertures, due to its modern, aspherical element design, then it seems like it would be a pretty good buy for the person who wants a 50mm lens that is good at wide-open or nearly wide-open.
WHich one, 50mm 1.8 AF-D or 50mm 1.8 AF-AS G series depends first on whether your camera has an in-body AF motor or not...if your camera has an in-body motor, you can buy ANY 50mm Nikkor, and will probably be happy. If you have a lower-end model without an in-body AF motor, I'd definitely say to stick with the AF-S series Nikkor lenses.
Garbz said:One should qualify "film" cameras. There are plenty of Nikon "film" cameras which do not use the aperture ring. The 1.8D will work on camera bodies which require an aperture indexing system. The F4 had digital control of the lens aperture and was released in 1988 ;-)
That statement is a gross over-simplification.The 1.8G will work on cameras without a built in motor, the 1.8D will not.
Allan
KmH said:That statement is a gross over-simplification.
The 1.8D will work just fine on cameras that don't have a built-in auto focus motor, but you would have to manually turn the focus ring on the lens until the in-focus indicator in the viewfinder lights up indicating focus has been achieved.
