eja
- Joined
- Jan 20, 2019
- Messages
- 31
- Reaction score
- 6
- Can others edit my Photos
- Photos OK to edit
- Thread Starter 🔹
- #16
First, thank you all for the input. I have been going back and forth between horizontal and vertical orientation while doing headshots. Not sure which I like more. And yes, I did apply the softening to the whole image and then inverted the application with a mask. I then brushed the texture back into the image. I probably did not do it even enough while brushing it back in. Also, I will experiment with lowering the main light and try to bring the highlights on the forehead under control a bit more.
For me, the least favorite thing to do is edit a picture, because I'm sooooooo slow at it. A skill set I'm trying to work on, but it is not fun for me at this point.
Also, Braneack, I'm not sure why the earings are sharp given that I applied the effect globally and then brushed back in the detail. I did not notice that. I'll go back and check the mask on that image.
Again, Thanks all for the input.
