Posing Suggestions?
Diannahunte
California
I'm Actually not a photographer, but am new in a Cosplay group, and we're going to be having a professional photo-shoot soon. I have been working with the rest of the group to learn how to use my face to convey the emotions of the character I'm playing, but my biggest problem is that I am rather large girl, and am awkward on film because of it. Any Tips for how I might pose in order to minimize my body size on film and appear like I know what I'm doing? Any help is really appreciated.
Hi Diannahunte, I know the cosplay people have a lot of fun. I hope your photoshoot turns out well.
If you have a professional photographer, he/she will be able to guide you with your posing. Most people
are awkward posing (at least to begin with), you just have to somehow overcome and say bugger it, I'm
going to go for it.
Unfortunately, the camera can be unhelpful if you are a larger person. My only suggestion here is avoid
being too close to the camera (and a wide angle lens) - it will tend to distort everything. Most people
photography is done with a lens of between 80mm and 120mm. The reason is that from further away,
the things closest to the camera (usually the end of your nose) are relatively closer to the things
furthest from the camera, say the ears, and the result is the features are somewhat compressed.
Sorry if this doesn't make much sense, it is hard to explain without examples.
Above all, it is about attitude. Just go for it :-)
Yes, there are plenty of ways to make a person look slimmer in photos. Much of it will have to do with the photographer....so things like the lens (focal length) which relates directly to how far the subject is from the camera. The farther away you are, the flatter the image tends to look. That doesn't necessarily mean thinner, just flatter. But you typically want to avoid being too close, as that will lead to wide angle distortion...but then again, that can be used for great shots, especially when the photographer knows what they're doing. For example, a wide angle lens that is above your head, will make your head look large and your body look much smaller in comparison.
Another thing will be lighting. A general rule is that 'short' lighting will make people look slimmer than 'broad' lighting. This has to do with which direction the model is facing, in relation to the camera and the position of the key light.
As far as posing, keep in mind that the more 'square' you are to the camera, the larger you will tend appear in the photo. That's why we usually pose people with their body/shoulders turned to the side (either a little or a lot). Of course, some body types won't look as good when seen in profile, so they may look better from a more frontal angle. Of course, the intent of the photo should play a part in the posing. If you are dressed up as an imposing, strong character, you may want to pose straight on to the camera to emphasize those characteristics.
There are some little tips, that you may have read already. For example, if you put one leg closer to the camera, keep your weight on the back leg. A very useful tip is to shoot people from above. This can make their body look smaller (in relation to their head, as I mentioned before) but this also has the effect of making the subject look up to the camera. As a person looks up, they stretch out their neck, which will slim it. And as you're a girl and this is cosplay, I'd guess that you might be showing some cleavage and by shooting down, they can really emphasize this to your advantage.
On a similar note, one thing that helps most people to look a touch slimmer, is to push their jaw forward while posing. This isn't usually a natural feeling for most people...actually, many people suck their chin in when they see a camera. I have to constantly remind and reinforce people to push their jaw forward. It stretches the chin & neck, making them look slimmer. Practice this in the mirror and get used to the feeling. Then try to do this during the photo shoot. It's hard work and even harder to remember to keep it up, shot after shot...but it really does work.
Lastly, don't worry too much about being a "rather large girl". Being comfortable and confident will trump that and can really show through in the photo. I'd guess that with cosplay, it will help if you really get into character and forget about any shyness or awkwardness that you may normally feel. Have fun with it!
Recently a friend of mine had some portraits taken. She is rather large but the photographer decided to get on a ladder and shoot her from above and behind her with her facing up. The effect was nice and actually quite slimming. Of course a pro showed know tricks like this already and if not they are not much of a professional and yall should save your money and hire someone better. Did you view this persons portfolio or ask them what they would suggest? Its not nice to tell a photog that other photogs said they should do this without consulting them first. Mike has a good point about cleavage too. It keeps people focused on a certain place, lol, and not on other areas that you are more worried about.
