- Joined
- Nov 27, 2011
- Messages
- 7,726
- Reaction score
- 4,602
- Location
- St. Louis
- Can others edit my Photos
- Photos OK to edit
Awww, it's gone already -- I missed it.
Joe
Joe
I could do that! but then the information will be dead, and future corrections and additions will not be there. But maybe i will do that when it's more mature.linking to articles off site are against the rules.
if you wish people to read the article, post it here instead of as a link to a website.
It was fairly short broken down into segments which were redundant later on, with a menu on the left that jumped to that segment. OP must be from England too as the work Colour was used.Awww, it's gone already -- I missed it.
Joe
Or not from the states or CanadaIt was fairly short broken down into segments which were redundant later on, with a menu on the left that jumped to that segment. OP must be from England too as the work Colour was used.
edit: Hey, look ... ^^^ there it is above.
edit: Hey, look ... ^^^ there it is above.![]()
The site contains at this point the following tutorial:
Colour
The light hitting a spot on the image sensor will have a specific colour temperature if it's a clear colour.
If it's a greyish color it is a mix of many colour temperatures. If the image sensor is a colour sensor, it usually contains three different types of receptors that react to different colour temperatures. Usually these colour temperatures are the temperatures of red, green and blue. This gives us the colours on a picture.
Focusing distance and depth of field
Since the introduction of the lens in cameras we got this effect. It does that the image is sharpest on objects at a given distance from the camera called the "focusing distance". The more the distance of an object deviate from the "focusing distance" the blurrer it becomes.
I try to explain it.
Let's take the example of the magnifying glass and the sun. The magnifying glass is positioned above the tablecloth so that the sun is maximally focused. This makes a sharp small image of the sun on the tablecloth. The image is sharp because we adjusted the distance of the magnifying glass so that the (almost) parallelly coming light from the sun is correctly focused on the cloth. If we replace the sun with a flashlight 50 cm above the magnifying glass the image of the flashlight will be blurred. The reason is that the light from the flashlight will hit the edge of the magnifying glass with a different angle than it hits the centre, while the sun hit's both places with the same angle. The light hitting the magnifying glass near the edge will not be reflected to the same point as the light going through the centre, but by moving the magnifying glass further away from the cloth this will be corrected, and the flashlight will be sharp. This is how one can adjust the focusing distance
The depth of field is the distance from the focusing distance that still is considered acceptably sharp, this point depends on the size of the lens. With a large lens the depth of field will be short, and with a tiny, tiny lens objects at any distance will be sharp
Another very important effect from this is that it affects the "depth of field" since a smaller aperture hides parts of the lens making the lens act smaller, and as explained that will give a longer "depth of field".
Controlling the exposure by amplifying the exposed picture electrically.
Throwing correct concise information is exactly what newbies need. Photography is not some simple little process we can throw a few simple analogies at and have it mean anything. If it was, anybody and everybody would master the craft in a day or two. The art of photography is a complex process based on physics that needs to be understood correctly from the very beginning. Doing so eliminates many beginner issues.I'm sure the
I think this does a far better job. Digital Photography Tutorials
Plus it's not spam.
I'm sure you are right in that, but that site is quite heavy. I have collected the most central aspects shortly, and your referenced site may not be the best one to throw at someone that just has started. What i have tried to collect is the things i wish someone would have told me when i started. It may not fit all, but if someone sees it as useful i'm happy. I would also be greatful for replies of faults in the information![]()
You're on the right track with a few things here, but you've also got a lot of errors and confusion going on here. I'll make a few notes to help.
ColourThe light hitting a spot on the image sensor will have a specific colour temperature if it's a clear colour.
"clear" colour is not appropriate terminology -- we don't use the term "clear" colour and it has no meaning.
You seem to be confusing light wavelengths with color temperature. For example white light is made up of the full spectrum of visible wavelengths but nonetheless will have a measurable (single) color temperature.
Focusing distance and depth of fieldSince the introduction of the lens in cameras we got this effect. It does that the image is sharpest on objects at a given distance from the camera called the "focusing distance". The more the distance of an object deviate from the "focusing distance" the blurrer it becomes.
DOF isn't focusing distance. That whole sun, flashlight magnifying glass bit needs to go -- it's a convoluted mess.
DOF does involve a range of acceptable sharpness. It does not depend on the size of the lens. Lens focal length is one of many factors involved in determining DOF.
Making the lens act smaller is not a correct explanation of how the aperture alters DOF.
ISO is commonly talked about using the "amplification" analogy but that's got a lot of problems. ISO does not control exposure and amplification in the sense of increasing something as the term implies is incorrect.
Back to work.
Joe
That's the most important thing, isn't it. The mastering of the technology is not enough. Without artistic skills you will not succeed in photographyAnd this is why I stick to taking photos... lots of pretty photos...
I'm aware ofthis, but in the heat of writing, the terminology easilly becomes inexact. Especially when i try to write in a language understood without any photographic background. Still it's good to not have false information, so i will correct this. Thanks for this noteDid you know:
1. The image sensor pixels in a digital camera are not digital. They are analog light sensors that store a small electrical voltage proportional to how much light falls on them during an exposure.
The sensor sees only the amount of collected photons, yes. But there are grids of color filters that makes a part of the sensor only be hit by photons from the red spectra, another part by the blue spectra and the rest by the green spectra. When i try to explain this simply i say that some pixels see red, some blue and some green.Did you know:
2. The analog light sensors (pixels) cannot 'see' nor record light color temperature. They can only 'see' and record luminosity. In other words they can only 'see' and record shades of gray from white to black.
To be honest if I was starting out, this article would confuse the crap out of me. LOL
