pgriz
- Joined
- Jul 30, 2010
- Messages
- 6,734
- Reaction score
- 3,221
- Location
- Canada
- Can others edit my Photos
- Photos OK to edit
It's an interesting door. Details around it are suggestive, but not enough to really construct some kind of story or narrative. The composition is good, in my mind, in that youve included enough wall on the left to move the door off center. I like your original more in terms of tonality than runnahs edit, partly because there is more detail in the lamp and the interior. The slant in the door, relative to the lines of the wall planks, imply a certain amount of decreptitude (yeah, thats a word), that reinforces the feeling of peeling paint, and broken screen. Its well photographed, but at the same time, its a vaguely depressing photo, mainly due to the subject matter.
As for your focusing issues, the only way to piece out what is going on is to test one variable at a time, keeping all the other things constant. If your camera supports live-view, then I think this is the most accurate way of getting the focus nailed down, as the image is read off the sensor. In doing these kinds of tests, everything is set to the base level, and all the automatic things are turned off. Putting the camera on a tripod is a must, as are all the vibration supression techniques (mirror up, remote release, etc.). The target has to have enough detail to be barely resolvable under the best of conditions, and the light needs to be constant during the test session.
I had some image softness when I upgraded my camera and it took me a while to figure out that my protective UV filter was the cause of that problem. When I upgraded my kit lens to the 24-105mm, it seemed to be softer than I was expecting. After doing the testing, I determined that the camera was back-focusing, and had Canon adjust the AF. I also learned that my cameras AF is good but not great any shot where the detail MUST be there, is shot on a tripod, with live-view focusing at 10x, and the usual plethora of techniques to suppress camera vibration (IS off, AF off, manual focus, mirror up, remote release).
I hope you are able to figure out what the issues are in your case (Im talking camera, of course!
That's the bad thing about the internet, you can't SEE the other persons response. I was 100% serious. You hit it on the head and described exactly what the photo was supposed to say. Run-down, decay, neglect. It's all there and you summed it up nicely. Again, the best compliment I received so far. Thank you
