darich
- Joined
- Jan 22, 2005
- Messages
- 1,230
- Reaction score
- 1
- Location
- Near Lanark, Scotland
- Can others edit my Photos
- Photos NOT OK to edit
- Thread Starter 🔹
- #16
Digital Matt said:The purpose of the EF-S lens mount is to let the lens protrude farther into the body. It allows them to make super wide angle lenses cheaper, and lighter, with fewer elements. It doesn't change the fact that the sensor is not the same size as a 35mm negative. The DSLR is based on the 35mm format in order for it to use normal 35mm lenses. You can't switch formats mid stream.
I realize this whole crop factor is another issue, but I think it's one to consider when buying a full frame camera. It's really one of the major perks to getting the 5D.
I know it doesn't change the size of the sensor or change the 1.6x factor but i thought that because the EF-S lenses were made specifically for cameras with a 1.6x factor, the lens was made to accommodate this and 10mm was actually 10mm and not 16mm.
