Shutter problem :/
Nurez
Iceland
Hello.
I have been using my camera, Nikon FG, these last few days, and on this last film I have had some weird problem with the shutter.
Sometimes (randomly) when I press the shutter it just opens and doesn't close. I figured out to close the shutter again I changed the speed setting to B (bulb) and then it would close again.
Is this a regular problem with film cameras? Is it something I can fix on my own?
Thank's.
kv. Nóri
compur
L.A.
Have you tried changing the batteries?
OP
N
Nurez
Iceland
hmm .. nope .. I thought the shutter worked manually/analog, (that is didn't operate on batteries.) I'll try changing the batteries, thank's for the heads up :)
If anyone else would like to comment on the matter please do so.
OP
N
Nurez
Iceland
p.s.
I took the batteries out of the camera and tried the shutter without them, it doesn't close, the same way as my problem before... it seems that it was the lack of battery power that caused the problem.
Thank you very much.
compur
L.A.
The FG has an electronically-based shutter which requires batteries to operate.
OP
N
Nurez
Iceland
You seem to have some knowledge about this camera that I don't yet have.
Do you by any chance know how to fix the counter (the numbers that tell you how many photos you have taken on the film), it has been broken since I got the camera.
Is this something that I could figure out by myself? or do I need some professional to take apart the camera and work some magic?
compur
L.A.
There is very little on most any SLR that is user-serviceable. If something breaks it's usually
most cost effective to find another body that works rather than send it in for repairs.
Trying to repair it yourself will usually result in disappointment.
OP
N
Nurez
Iceland
hmm.. all right. Thank's for all your help : )
David A Sercel
Florence, Alabama
Website
www.davidaaronsercel.com
Don't know if this will help at all... I have this same problem with my Ricoh KR-10, but only when I use it in A-priority mode. The shutter opens and sticks until I turn the shutter speed dial to a different position. Everything works wonderfully as long as I leave it in full-manual, so I can only guess that there is perhaps a short somewhere in the auto-function circuitry.
