o hey tyler
- Joined
- Aug 3, 2009
- Messages
- 9,784
- Reaction score
- 2,727
- Location
- Maine
- Can others edit my Photos
- Photos NOT OK to edit
kassad said:I appreciate you testing this on your testing this on your camera. The results your giving would be acceptable for me if they were on the a77. Even with the advertising specs ie 14 shot buffer the a77 is the worst of the enthusiast level cameras. Canon 7d 8fps 100+ shot buffer Nikon d300s 8fps @50 shot buffer.
One of the major problems of the a55 and a33 when they first came out was that after some one did a full burst in the high speed mode the camera completely locked up for several seconds while the buffer cleared. With the later firmware updates that problem was fixed. Now they throttle back the burst rate when the buffer is full.
I wish someone with a a77 would do this same test and post the results.
The a55 and a33 had that issue. They said the sensor overheats quickly.. But if you turn the IS off, you can shoot longer in full burst. The issue has been fixed in a35. When I rented my a77, I tried doing a full burst 12fps but for only like maybe 15-20 seconds and stopped. That's all I can tell bro. I just wanted to try out the 12fps but didn't want to break my rented camera.
You didn't want to break a camera that is "capable" (I said capable, not good) of shooting 12fps which is in the scope of normal operation?
OH JEEZE GUYS I DON'T WANT TO SHOOT THE 7D AT 8FPS BECAUSE THE SHUTTER MIGHT BREAK. IT'S NOT ENGINEERED TO DO THAT KINDA STUFF GUYZZZ.
Granted, the 12fps is kind of useless because you have to be in a fully auto mode to use the 12fps. The parameters of the auto mode lock the exposure for the first shot, and expose the frames at 12FPS based off of the first exposure. So if the metering is off in the first shot, it's off for the entire burst. Or if you are following a subject from bright sun, to shade you'll just have an underexposed series once they get into the shaded area.
SICK FEATURE. Totally ditching my FF Canon gear and fast primes to use an A77 w/ 12FPS continuous drive at ISO1600 or above. You know, because the noise handling is REALLY GOOD... And then I can turn all the images into HDRs IN CAMERA! Because that's a really valuable feature for professional photographers in the field! THEY ALL WANT DAT HDR @ 12FPS BRO.
OH WAIT, I can make 3D photos! Another thing that ALL PROFESSIONAL PHOTOGRAPHERS care about! EVERY SINGLE ONE OF THEM.
