As a result even a processed RAW photo can look different when only the white balance is set when you use different software approaches.
If you shoot in raw it HAS to be processed at the very least. Processing is subjective.
If you shoot in jpeg the camera edits-and you can somewhat control that also.
If you shoot film it must be developed, the way that it is developed has a major impact upon how you see the image. It's also subjective to the developer.
So, would you like to start over? Because there is no such thing.
On theory I have for the differences in the differences of view (as Unpopular is showing) is that 0 isn't really the same 0 on different RAw processors. 0 contrast on one program might be at a different point to 0 contrast on another. As a result even when a user sets the numbers to the same values, the actual view adjusts.
It should be noted that, with adjusting the values, most RAW processors will give the same resulting image - differences between them after editing are often so marginal as to be impossible to notice. Furthermore it should be noted that most of the differences tend to be only present on very specific types of photo (the nature of which are such that you can't "shoot" this type of photo with intent in any situation).
As a result most users are pretty free to choose whatever RAW processing software suits your needs.
variation will exist from one algorithm to another.
Every photograph is "edited" in some sense. The question is where you stop, not whether you do it or not.
Yup, every photo is editied in some way, whether it is by your camera or by a human. Maybe you mean you like photo's that aren't enhanced? That could be a whole different story..
Beginners often have such high regard for raw "untouched" images. As they progress, they know better.
Here is a godo example of this. Below are two renderings of the same raw file. The first is processed with Photoline's built in and rather lousy RAW processor, the other is processed using RPP. As you can see, processing in this case made an huge difference in resolution and sharpness. Furthermore, straight out of the processor, the shadows are also rendered differently. One would think that if the data a processor is fed is the same, the results will always be the same. But in reality, this is far from the truth.
Noise is rendered even more dramatically different.
