- Joined
- Mar 8, 2011
- Messages
- 25,396
- Reaction score
- 9,149
- Location
- Iowa
- Can others edit my Photos
- Photos NOT OK to edit
.... as i was capturing him .......
..........I received the image as a raw file...........
Huh?
Not possible as imgur doesn't allow a raw format.I received the image as a raw file, uploaded on imgur and that was what it showed.
Besides the overpowering yellow of the hoodie, the image is tilted; the buildings aren't vertical.
It's underexposed, again probably because of that yellow. If you were using matrix metering, the camera took in the entire scene and averaged the exposure. You'd need a spot meter on his face, I think. Also, focus on his face. I think the face is slightly out of focus, while the logo on the hoodie is pretty sharp.
Generally, this is just a snapshot of your bud in the 'hood.
As for the squint, have him keep his eyes closed while you count down to the shutter. He should open his eyes just as you click the shutter, and his eyes won't have time to react to the light, i.e. squint, before the image is captured.
spot metering was used and it was always focused right in the middle capturing the subject eyes.
The camera's light meter spot may or may not be at the focus area. Check the user's manual to find out how to spot meter and select the focus area.I had put the spot meter on his eyes as that is the general rule, weird that the logo was much sharper than the face.
......Generally, this is just a snapshot of your bud in the 'hood....
....what do you mean by that? ...........
obviously i could cropped out the legs as i was capturing him using AI focus. my lowest aperture was 4.0 on the lens, so that's the best i could do with shallow depth of field.
can you critique it, and also give me some pointers for improving this image on software like photoshop?
Imgur
thanks!
I think it harmonizes well with the location you used
position yourself and the model in ways so you can use details of a location to frame your subject rather than intersecting with them.
This image reads to me as a fashion image, and as such I think you could try getting the entire outfit in the frame, head to toe
I know the commenter above said photoshop doesn't help a poor photograph
I disagree about your comment on this being poor lighting. I personally think it's quite good, and was also a well executed use of a difficult to use light source. As for not knowing why the image was taken, the OP has commented saying that this is a fashion image, and to me it translates very much as a fashion image.My first reaction was that I didn't know why the photograph was made. Is it meant to be more than a snapshot of a friend while on a walk in the city?
I think the background is soft enough. Zoomed to 105mm, your lens should be fine. The only other way to soften the background with that lens is to move in closer to your model.
What he said was Photoshop will not improve your photography. A photograph can be improved with Photoshop, but not your photography.... your ability to make photographs. Continue to learn to get the results in the camera.
If this is not a photo of the yellow hoodie, then you need to do additional photography.
Try to develop your ability to "see light." This image is lighted with a nearly perfectly flat light source... very much like an on-camera flash. Even IF it's meant to be a shot of the hoodie, you'll communicate more shape and texture with your main light off axis.
Good effort! Enjoy the journey! It's very gratifying as you develop your skill.
-Pete
