Jimmahbee1
- Joined
- Jun 2, 2018
- Messages
- 5
- Reaction score
- 0
- Can others edit my Photos
- Photos OK to edit
It HAS to come apart somehow, mate. They put it together once. I think I see a set screw in the side, so loosen/remove that, then try again. Or look for some other mechanism.thank you so much for the fast response...! the problem is that this piece underneath doesnt unscrew...I need this to hold a video camera
It doesn't HAVE to unscrew! On some cheap tripods the head is an integral part of the column held on with a circlip and is not meant to be removed.It HAS to unscrew, mate. They put it together somehow. I think I see a set screw in the side, so loosen/remove that, then try again.thank you so much for the fast response...! the problem is that this piece underneath doesnt unscrew...I need this to hold a video camera
