Trying to train my "Vision"
IMO as presented there are a few problems. Here's a quick edit and the theory behind the changes. First the image is really flat, lacks punch. I adjusted the exposure, contrast, white, black and clarity. Second, I bumped the shadows globally, it could still use some localized adjustment on the woman's face, but it brought out the store window details sufficiently to add interest. I thought the little pedestrian walk sign was a nice touch. Last I cropped to a 14x11 landscape. Doing this brought the woman in as your focal point, and using the rule of thirds, put her directly on the left vertical, with her head/face on the top left intersection. On the right I cropped at the edge of the sidewalk. Doing so gave a nice leading line from the sidewalk all the way through to the white line on the pavement, gives depth to the image, and a sense of direction from which she came.
I was wondering if you could help a fellow newbie here and possibly go into more detail as to what all you did here - " I adjusted the exposure, contrast, white, black and clarity. Second, I bumped the shadows globally" So that when I take a B&W I will know what little bit to do in PP to make the shot less flat and add a little punch.
That's been awhile and I do well to remember what I did yesterday. However in addition to the above, I worked with the curve, sharpness and luminosity sliders, and all of it was done in LR. Unless I have some really serious editing to do I don't go into PS.
A lot of the "pop" you refer to takes place in the tone curve. Here's some basic information to start you off How to Use the Tone Curve Panel in Lightroom - Photography Life . Read up on everything you can find on using the tone curve as it is one of the most useful tools in LR.
Another element of the "pop" is in sharpening and noise. Sharpening is easy to get wrong as is noise, I've seen both overdone. here's some reading to help Sharpening in Lightroom: Make the Most Out of the Detail Panel
Adding sharpness, contrast, noise.....to an image willy nilly without a good image to begin with and a solid understanding of why you are adding to it, seldom results in anything but a bad image made even worse. Read up on the elements of composition so you can learn to envision an image before you snap the shutter.
Unfortunately I don't have LightRoom. My main source for editing images is Gimp, though I can pretty much do almost the same in Gimp now knowing how you did things. Thanks for the reply, its greatly helpful.
