kundalini
- Joined
- Jul 18, 2007
- Messages
- 13,607
- Reaction score
- 1,937
- Location
- State of Confusion
- Can others edit my Photos
- Photos NOT OK to edit
I think it's time to get a Bird Bath (Beauty Dish). This accessory has been on my Wish List for quite some time. The latest issue of Rangefinder was themed as The Lighting Issue and got the juices flowing again. Any opinion from users of what you like from what you have (silver of white) and what you seem are producing less than expected results.... making you think the other choice might have better suited your purpose. If you have both.... P-L-E-A-S-E chime in. My initial purpose is for portraiture, but know enough that a it can be utilized in a multitude of other uses.
I have PCB lighting, so that's likely the Dish I will go with. Here are the descriptions from the PCB website for the silver and white.
Silver
White
I have a sneeky feeling that the silver will give me more options. At times, I really like harsh lighting and the silver would offer more specularity, but add on the sock and it can be toned down to offer soft light.
Also, $30 for a carry bag? It's a sturdy aluminum (?) product, much like the LiteMod mainframe, right? I see that as an uneccessory expense.
Thanks for your insight.
**If you do not have first hand experience using one, please read, follow along or ask questions. But your opinion on its useage would be less than useful.
Silver
The 22-inch High Output Silver Beauty Dish creates a bright, highly-efficient light source with a narrow 45° beam spread. When used close to the subject, the narrow beam spread allows a more selective area of coverage. With about six times the efficiency of a white dish, the silver dish can be used to light subjects from greater distances as well, even with low power flash units.
The reflector arrives with an optional direct-light blocker. Direct light from the flashtube is blocked, allowing only bounced light from the reflector to fall on the subject. This reduces the degree of reflections from shiny specular objects.
Because of its geometry, the Silver Beauty Dish provides a somewhat higher degree of shadow softening and the finish allows more specularity than the White Dish. Even more specular response can be achieved by using the Beauty Dish without the included direct-light blocker. The result is a small center light source (the flashtube) surrounded by a 22-inch circle of reflected light that enhances reflections from shiny objects such as sequins, jewelry, etc., and achieves maximum pop.
The reflector additionally arrives with a translucent white diffusion sock that converts the Silver Beauty Dish into the equivalent of a round softbox with very even coverage and outstanding evenness across the face of the diffusion fabric. This widens the angle of coverage to about 150° and lowers the output by about 2-1/2 to 3 f-stops. It also minimizes the specularity and results in approximately the same photographic result as a conventional white beauty dish with diffusion sock.
As with any light modifier, there is no right or wrong use. Its up to the photographer to use the light and modifier as best suits his/her intended purpose. Generally, one should consider using the Beauty Dish without the direct-light blocker when lighting from a distance. Because of its very high output in this mode, the Beauty Dish is an ideal tool for shooting weddings or other events, and for high key studio lighting with the light placed around 7 to 20 feet from the subject. For closer, more intimate lighting, using the diffusion sock will allow wider coverage and lower specularity. Using the Beauty Dish without the sock will result in more selective lighting and higher output, though this use may be challenging when higher power flash units are used due to the very high output of the Beauty Dish.
White
The 22-inch High Output White Beauty Dish creates a bright, highly-efficient light source, similar to that of the silver dish, but with a softer finish. The white dish produces smooth skin tones and even coverage that could normally only be achieved on the silver dish by adding the diffusion sock. With a beam spread of 130° without the use of the included diffusion sock, the white beauty dish is great for indoor portraits to create warmer skin tones, or for diffusing hot spots that might occur on shimmery fabrics or reflective surfaces.
For even softer results, the White Beauty Dish additionally arrives with a translucent white diffusion sock that converts the reflector into the equivalent of a round softbox with very even coverage and outstanding evenness across the face of the diffusion fabric. This widens the angle of coverage to about 150° and lowers the output by about 1 to 1-1/2 f-stops.
<snip, same as silver>
